Brain Teaser
Old Jun 9, 2015 | 07:36 PM
SuperVetteC5's Avatar
SuperVetteC5
Default Brain Teaser
Ok, here's the deal. Just installed an Alky Controll Kit in my 04 Z06 that has 15K miles on it. All hooked up but not in service. Didn't fool with anything that would affect running or operation of the car. Went to start it and, nothing. All gauges work and sweep like normal, battery is fully charged. So....started fooling with the clutch switch and it started....got it right? Wrong. Bypassed the switch and same deal, had to fool with the plug for the switch, got it right? Wrong!! Bypassed that and same deal. Finally figured out that I have to hold the key in the start position for about 5-10 seconds......then it will start!!!
What in the world would cause that??????
Old Jun 10, 2015 | 01:32 AM
StingrayRebel's Avatar
StingrayRebel
you didn't happen to tap into any of the ignition switch wires did you?... if so I would find another 12v source other than the ignition wires
Old Jun 10, 2015 | 10:10 AM
SuperVetteC5
Thanks for the reply. I found the problem with Shant's (Chicago1) help. He had experienced the same thing. I had tapped in to the accsy off fuse with an add-a-circuit and it was causing the problem.
Nice to have this place for info, it sure saves a lot of time and effort.
Old Jun 10, 2015 | 01:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The 04 C5 doesn't have the AUX Power pig tail wiring harness in the passengers foot well that all the other C5s did. That being said, ALL C5s have a SPARE IGNITION SWITCH circuit that you can ADD A Wire and terminal and be able to have a switched HOT circuit.
Here is the Ignition switch that shows the UN-USED switch:
Bill
Old Jun 10, 2015 | 01:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can also add wires and tap into the ACC positions on the other switches.
You will have to unseat and remove wire terminal OR add a female pin to the Ignition switch connector and crimp or solder a wire to it.
To Brain Teaser
