Dash Cluster
Old Jun 22, 2015 | 07:07 AM
UZISOLO's Avatar
UZISOLO
Default Dash Cluster
On my current cluster my Tach keeps dropping off line to zero, found me a used cluster with about 70 G's on the cluster. Should I have the used cluster programmed before I install it? And what's the propose of programming the dang thing?
Thx
Old Jun 22, 2015 | 11:27 AM
dadaroo's Avatar
dadaroo
Any good Speedometer shop should be able to do it off the car. I don't think you can do it off the car with a Tech 2. I have a spare IPC and a Tech 2 but right now I just don't have the time to try it. My biggest client just put me on a project but if I can find some time I will try it. I have been curious about that for some time myself.
Do you have the guidance for pulling the IPC? If not, I can provide it.
Old Jun 22, 2015 | 12:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It CAN NOT be accessed / changed with the TECH 2.
You have to have a dedicated interface that can program the odometer processor.
Call your local dealer and if they cant do the process,, they will most likely be able to point you in the right direction for a shop that can.
BC
Old Jun 22, 2015 | 10:13 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
My 03 Suburban cluster was acting up, tach stopped working, speedo started at 40, fuel gauge work/ not work. was ready to yank the tank and replace fuel sensor/pump when other issues started. There are tiny servo motors that control each gauge. Not sure if the Vet is the same way. Anyway, found a guy that rebuilds the cluster for a c-note, all new servos and bulbs. Cluster came out in 5 mins., packed and mailed to him and back within a week, was still able to drive the car with it out. Might want to call him and see if he does Vets, here's info:
Carl Rimmer
270-993-9533
chevyspeedo.com
dallasman999@gmail.com
Old Jun 22, 2015 | 11:40 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Before you get too deep in repairs,,, Please read and post the DTCs using the DIC code reader. If you have a LOT of DTCs,, clear them, and take the car for a short drive and see what comes back. Especially interesed in NO COMMS information and U series DTCs for this issue:
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
I always read my DTCs prior to turning OFF the ignition switch. If you have any messages on the DIC,, PRESS RESET until they are gone!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect.)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, "C" or "H". A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Jun 23, 2015 | 01:07 PM
lionelhutz's Avatar
lionelhutz
I'd try it and see if it works before spending any money on it. I believe the mileage is stored on the main cluster board so you could also try swapping the main board and see if it still works.
To Dash Cluster
