headlight ??
Old Jan 14, 2016 | 10:57 AM
xzo124's Avatar
xzo124
Default headlight ??
Couple years back I installed the kit that makes all 4 headlights stay on when on high beam .. now they wont work on lo beam , work only on high beam as supposed to .Could it possibly be the relay or maybe a headlight switch??..TIA ...xzo
Old Jan 14, 2016 | 02:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have the KIT Wire schematic please reference it or post it. Could be the OEM parts or could be the Aftermarket parts.
Schematics and a Meter are your friend!
Bill
Old Jan 14, 2016 | 03:22 PM
xzo124's Avatar
xzo124
Bill
I purchased it from someone that had an AD off of this site , but for the life of me I cant remember who it was . Im not getting any power to the low beam fuses in the fuse box. the piggyback wires from high beams make them work like they are supposed to . The headlight buckets will not close unless its on High beams .. I really dont think its the kit . Think its some OEM part...Thx Bill ....xzo
Old Jan 14, 2016 | 04:35 PM
LoneStarFRC's Avatar
LoneStarFRC
If your aftermarket system has a dedicated wiring harness that uses relay(s), replace the relay.
Except for the headlight door weirdness you described, I had this exact same symptom on my aftermarket HID system. After troubleshooting the fuses OK, I replaced the relays (I have HID in both high and low beams) and Badda Bing........
HTH
Old Jan 14, 2016 | 09:49 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
This thread may help.
https://www.corvetteforum.com/forums...n-at-once.html
To headlight ??
