What seals to replace while trans is out?
Old Jan 14, 2016 | 02:45 PM
Tim1137's Avatar
Tim1137
Default What seals to replace while trans is out?
I'm going to be removing my transmission in my 97 6 spd next weekend, and I'm having a tough time figuring out exactly what seals to order.
I know I need one output shaft seal p/n 88996703 and two differential side O-rings p/n 89047953.
Someone mentioned there is a big seal that goes between the transmission and differential too? and a rear cover seal? Hoping someone can clear this up and tell me what to buy
Old Jan 14, 2016 | 10:00 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
There's an inner and outer OPS seal. You have to remove the extension housing to replace the inner one, and you'll need an extension housing gasket). I wouldn't replace them unless you have a known leak there (it will be obvious). If you do need them:
I can't find the part number for the extension housing gasket but Gene Culley at CULTRAG will be able to locate it for you. It was around $50
Output shaft seal (inner) 19206242
Output shaft seal (outer) 12455045
(make sure you note the orientation of these seals before removal. If you install them incorrectly they WILL leak).
What I would replace:
There is a large o-ring that goes on the extension housing 12369456
Get 2 o rings for the diff covers 89047953
get 2 axle seals for the diff covers 88996703
Rear cover o ring 89047954
Old Jan 17, 2016 | 02:00 AM
onspeed's Avatar
onspeed
Did this last year, I replaced pretty much everything listed here. The extension housing gasket is just RTV.
I would also add that it might be worthwhile to change the differential belleville washers. I found one of mine cracked, which I think is common, and went ahead and replaced them with C6 pieces. Requires a little more work and a press + a special tool (think I paid like $25 from eBay - will probably post mine for sale soon as I shouldn't ever need it again).
Used these threads as a guide
https://www.corvetteforum.com/forums...post1573407966
https://www.corvetteforum.com/forums...-z06-guts.html
Good luck.
Old Jan 17, 2016 | 02:35 PM
CamminC5's Avatar
CamminC5
Only use RTV on the extension housing if it had RTV from the factory. If it had a gasket you need to use a gasket. The differences in clearance between the 2 could throw off measurements.
Old Jan 17, 2016 | 08:58 PM
onspeed's Avatar
onspeed
For some reason I was thinking they didn't start using a gasket until C6, but I found a post by RPM on LS1tech that 2004-on was the change to a gasket.
Old Jan 18, 2016 | 09:17 AM
CamminC5's Avatar
CamminC5
It's all good man. That's what we're here for.
Old Jan 20, 2016 | 09:03 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you very much for the referrals. I certainly appreciate it. We appreciate your business and patronage.
Old Jan 21, 2016 | 10:13 AM
CamminC5's Avatar
CamminC5
Your good people Gene. And your customer service is top notch!!
Old Jan 21, 2016 | 10:23 AM
Tim1137's Avatar
Tim1137
Guys, im coming up with part # 19259473 for the rear axle seals, but some threads here are telling me to buy part # 88996703.
What's the difference?
Old Jan 21, 2016 | 10:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to be a little more educated with your differential construction. Here are a few post that will help you see what inside and how it works and some of the simple improvements that you can do while you have it out.
I did this to my differential and its doing excellent and easily supporting 450 RWHP driven hard.
I ordered almost ALL the upgrade parts from Gene Culley and he was excellent with helping me with the parts order and making sure I had all the correct parts.
I did order a DTE spider gear cross shaft as it a good bit more heavy duty than the OEM part.
Check out these post if not for anything more than to see what you need to order and how to best service the differential::
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5, Its Go TIME, Differential Rebuild post: https://www.corvetteforum.com/forums...1&p=1591127325
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
I also included a manual transmission related post so you can see where those seals go:
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
Old Jan 21, 2016 | 11:14 AM
Tim1137's Avatar
Tim1137
Is there anything special that needs to be done to remove that extension housing? I know the diff bolts right off it, but to re-seal the extension housing to gearbox seal... does it simply side off, or is it more in depth than that?
I also can't seem to figure out if Dextron 5 is compatible for the transmission fluid.. No one sells Dextron 3 anymore.
Old Jan 21, 2016 | 11:38 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The extension housing simply unbolts and slides off. IMHO, I would order some AMSOIL Torque Drive ATF. It compatible with your early Transmission paper backed blocker rings and it a MUCH better oil than the OEM Grade DINO fluid.
There are several Forum Sponsor AMS OIL Dealers on here. Give them a shout and discuss your needs..
Old Jan 21, 2016 | 11:39 AM
Tim1137's Avatar
Tim1137
Thanks Bill, how many quarts should I buy of the ATF? I've seen anwyhere from 3-6
Old Jan 21, 2016 | 11:47 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The MN6/MN12 transmission requires FOUR quarts when its DRY (new from the factory)
When you drain the fluid and refill the transmission, it will only take 3.75 quarts. SO, you will always have a little left over when you are done the refill job!
http://www.c66racing-synthetics.com/ has AMSOIL supplies as well as forum member SUBDRIVER
Old Jan 22, 2016 | 05:20 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
88996703 is and old part # and have been superseded with 19259473.
__________________
To What seals to replace while trans is out?
