parking lights
Old Jan 21, 2016 | 02:22 PM
hdrider13's Avatar
hdrider13
5th Gear
Default parking lights
When I turn on my parking lights they dont come on rite away. That includes my dash lights too. This problem is on my 1998 c5. Could it be a bad ground?
Old Jan 22, 2016 | 12:44 AM
zachaeous's Avatar
zachaeous
I had a similar problem and ended up replacing the multi-function switch and the problem was fixed. There are contacts inside the switch that had lost spring tension. I believe that the switch could be repaired for a lot less than the price of a new one. It would be free if you do your own work. There are write ups here on repairing the switch on the forum. Good luck with your repair.
https://www.corvetteforum.com/forums...-a-how-to.html
Here is a link to the repair
