Special Grind Cam
Old Feb 6, 2016 | 10:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
Any machine shop worth its salt has something called a cam doctor. Bring your cam, their pc spits out all the specs usually runs under 100
Too many "secret" cams are just off the shelf stuff, probably sold with different names on them by different "tuners". Probably why they give them all goofy names instead of grind #s figuring most wont go to the trouble of finding out.
Old Feb 8, 2016 | 01:38 PM
enoniam's Avatar
enoniam
Originally Posted by wmjosjr
Thanks. If my red line is 6800 how will it still pull past that?
You can shift where you want. I'm just saying whether you shift at where redline is indicated or not, assuming the rev limiter in the computer isn't limiting it, that cam is set up to be giving really good power up to at least 7000.
Or in other words if you shift at 6800 that cam is probably not your best choice.
