C5 throttle body spacer
Old Feb 1, 2016 | 08:16 AM
JAEASTMAN's Avatar
JAEASTMAN
Cruising
Default C5 throttle body spacer
My mechanic wants to install a throttle body spacer on my 97 C5.
Any suggestions? Good or bad idea?
thanks,
John
Old Feb 1, 2016 | 08:19 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
waste of time and money !!!!!!!!!!!
Old Feb 1, 2016 | 09:08 AM
JAEASTMAN's Avatar
JAEASTMAN
Cruising
Default Throttle body
Thank you. Did you experience first hand?
J
Old Feb 1, 2016 | 09:15 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
didn't need to, just know better !!!!!!
Old Feb 1, 2016 | 09:23 AM
JAEASTMAN's Avatar
JAEASTMAN
Cruising
Thanks for the heads up.
Old Feb 1, 2016 | 09:39 AM
Velocity_Vette's Avatar
Velocity_Vette
There have been extensive tests of LS engines with throttle body spacers. Any gains would be negligible to largely none at all and ultimately they're not worth the rather high cost they are.
Spacers were/are very popular on carbureted vehicles, where fuel delivery occurs largely at the point of air entry. Fuel delivery on a modern electronic-fuel injected vehicle is way past the point of the throttle body. All you are effectively doing by installing a spacer is increasing the distance air has to travel to get to the intake which increases air velocity by an incredibly small amount.
If you want a better upgrade for your '97 that sees legitimate results, put the $120-$150 you would pay for a spacer towards an OEM LS6 intake upgrade - a much proven upgrade for early C5s in terms of money spent and "bang for buck". You will see legitimate power gains there rather than throwing your money away on a piece of molded metal.
Old Feb 1, 2016 | 10:23 AM
JAEASTMAN's Avatar
JAEASTMAN
Cruising
Thank you. Great information.
Old Feb 1, 2016 | 10:37 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Feb 1, 2016 | 10:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% ON THE MONEY ADVICE!
I just sold a mint unmolested LS6 (2001-2004) INTAKE MANIFOLD for $375. You can find them in the parts for sale section. EASY bolt on improvement.
The LS6 (2001-2004) intake has a deeper / larger plenum for added air flow. COMPARE the two below:
Here is a early LS1 intake manifold as distinguished by the curved more shallow bottom:
Here is a LS6 / 2001+ intake manifold. You can easily tell by the FLAT bottom:
BC
Old Feb 1, 2016 | 10:59 AM
JAEASTMAN's Avatar
JAEASTMAN
Cruising
but will it fit a 97?
Old Feb 1, 2016 | 11:19 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!!! You have to make some VERY MINOR modifications but its a direct bolt on 100% fit!
Your car will have the steam cross over plumbing under the intake manifold shown below. All you need to do is push the piping down so it rest BELOW the heads of the fasteners that secure the valve valley to the block. I used a plastic mallet and a small wooden dowel and massaged it so it was below the bolt heads and she fit like a glove!
OR
You can also purchase the rear block off caps and the front steam crossover pipe to convert it to the later 2001+ style set up.
You can see the BLOCK OFF plugs on the 2001 at the rear of the picture on each head:
Old Feb 1, 2016 | 11:44 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I used this kit, it is pricey but I wanted the four corners to bleed off the trapped air when filling the coolant system(there is a process to make sure you don't have trapped air in the LS engine) I filled mine and started it with NO issues!!!!
http://www.summitracing.com/parts/tf...0601/overview/
Old Feb 1, 2016 | 11:58 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL! I have an 02 ZO6 Came OEM with the rear block off plugs and NO pluming.
I did a heads, Ported FAST90 and cam mod and wanted the added rear cylinder venting benefit.
SO,,, I purchased an OEM 2001+ Front cross over pipe and installed it in the rear. Just flip it around and connect it to the front using a metal T fitting and some rubber hose:
Bill
Old Feb 1, 2016 | 12:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
now you tell me Bill, the LS engine was new to me (kinda) and at the time I installed my LS intake all I knew was the lines could be a clearance issue. I had also read that the LS engine trapped air so common sense told me that if all of the highest part of the engine were able to let the air out the easier it would be to fill the system !!! (and it worked)
Another note for the bypass,you could run a hose from the drivers cyl. head directly to the radiator !!!!! No extra clamps and fittings !!!!
Old Feb 1, 2016 | 12:25 PM
JAEASTMAN's Avatar
JAEASTMAN
Cruising
Bill
Thank you Bill. Great info.
Old Feb 2, 2016 | 04:37 PM
StudentDriver's Avatar
StudentDriver
Not to get too far off the intake train. But.
can you run the ls1 throttle body on the ls6 intake? Or would you recommend upgrading(not sure if there is anything to be gained) to the ls6 throttle body as well?
Old Feb 2, 2016 | 10:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
yes you can a few of the guys here have them polished !!!!!!!
Old Feb 3, 2016 | 01:05 AM
RonSSNova's Avatar
RonSSNova
It's the same throttle body. No difference.
To C5 throttle body spacer
