Spark plug boot
Old Feb 26, 2016 | 12:56 PM
3FloridaVettes's Avatar
3FloridaVettes
7th Gear
Default Spark plug boot
Any help appreciated in getting the boots of my plugs. They are really stuck . They have been on since new...12 years old.
Thanks. Dave
Old Feb 26, 2016 | 02:48 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Not really any good way to do it. Brute force worked for me. Large needle nose pliers with lots of twisting and pulling with an occasional poor choice of words... There has to be a better way.
# 5 and #7 are tough.
Old Feb 26, 2016 | 02:55 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
just plan on replacing them !!!!!!!
Old Feb 26, 2016 | 03:34 PM
searay340's Avatar
searay340
I used a long Cheap Plier that has a large round opening and does fit on the Metal plug shield. It worked for me especially the buried #7 plug. Nothing pulled apart but I did replace the wires anyway as they were the old OEM's ( now they are Spares) with the GM Red performance wires. You can get a set of 3 sizes in a package at Harbour Freight.
Old Feb 26, 2016 | 06:03 PM
Z06copley's Avatar
Z06copley
I used long needle nose pliers and disconnected them from the coil first, but at that age be surprised if one comes off in one piece. also for back driver's side, disconnect the vacuum line on the booster so you have more room to maneuver.
Old Feb 26, 2016 | 06:57 PM
fmvette9's Avatar
fmvette9
If you are going to replace the wires: I used vice grip pliers on the hex shaped portion of the boot. The locked in place pliers allowed much greater pulling force. Got them off in a jiffy but did destroy some of the wires. Also suggest to wear gloves...when they break free, watch out.
Old Feb 26, 2016 | 09:10 PM
There is a tool for pulling the wire boots off spark plugs - not very expensive and can probably be found at places like Harbor Freight, Sears, etc. Makes it easy to do the job.
Old Feb 26, 2016 | 09:27 PM
ZigZag's Avatar
ZigZag
Thanks. Dave
Pull, cut, tare, rip them off any way you can and replace them and the plugs. Good luck with the plugs also, they can be a real bitch. Add never seize to plug threads and spark plug boot & electrical connector dielectric grease with a cotton swab for help both getting the boots on and off.
Old Feb 27, 2016 | 08:49 PM
dmarkshark's Avatar
dmarkshark
I had luck getting mine off by twisting them.
Old Feb 27, 2016 | 09:59 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Nothing like yanking on a spark plug wire then falling on your **** when it lets go!
Old Feb 27, 2016 | 10:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
12 year old plug wires!! LOL! RIP PULL TEAR,, use a winch.. What ever it takes! Get them off. Save your cans (shields)
FACT! Plug wires do NOT make HP. DO NOT anguish over what new plug wires to purchase. IMHO,,,, The very best BANG FOR THE BUCK is the GM Red Performance wires. They fit properly, look great and are excellent wires. They are approx. $65.
I order mine from Gene Culley. - Gene Culley GM Parts: http://www.cultragfactoryparts.com/
Order some new Iridium GM plugs gapped at 0.040" and enjoy the new drive..
Bill
Old Feb 28, 2016 | 07:38 AM
corvet786c's Avatar
corvet786c
Bill
Where they at, its says $129.00 for 2002 corvette?
http://www.cultragfactoryparts.com/c...=plug-wire-set
Old Feb 28, 2016 | 09:17 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
http://paceperformance.com/i-6255255...e-set-red.html
Old Mar 2, 2016 | 09:18 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. You can find them at the link below. They are not in the standard catalog as they are a GM Performance Part and not a replacement part.
http://www.cultragfactoryparts.com/oe-gm/12495519
Old Mar 3, 2016 | 09:28 AM
huesmann's Avatar
huesmann
At 12 years old, you need new ones, so it doesn't matter if you destroy them getting them off! You need new plugs too!
To Spark plug boot
