front emblem removal?
Old Mar 9, 2016 | 03:39 PM
kennedy759's Avatar
kennedy759
Default front emblem removal?
can the front emblem be removed and reinstalled? going to have the front nose repainted.
Old Mar 9, 2016 | 03:52 PM
BetTheVette's Avatar
BetTheVette
I don't see why not. Should be able to use a heat gun to loosen the glue. Be aware that the front also has two small posts that fit into the bumper.
Old Mar 9, 2016 | 04:22 PM
zachaeous's Avatar
zachaeous
Yes it can removed and as stated in the previous post be careful of the pins that go into the bumper for alignment. I used a thin putty knife to remove it.
You will need new adhesive double sided tape and a razor knife to trim around the emblem for reinstallation. Cleaning the old tape off is a pain but it can be done.
Good luck with your repair
Old Mar 9, 2016 | 07:36 PM
69's Avatar
69
Cruise-In VI Veteran
Dental Floss
http://www.instructables.com/id/Hack-your-car-badges/
Cheers,
Goose
Old Mar 9, 2016 | 09:20 PM
73Corvette's Avatar
73Corvette
WD-40 and 90 lb fishing line...
Old Mar 9, 2016 | 09:52 PM
I would probably use a hair dryer as it will not get quite as hot.
Get some 3M double sided tape and trim the excess away from the emblem. Will hold just like the factory stuff.
Originally Posted by 69
Dental Floss
Works well.
Old Mar 11, 2016 | 01:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HA,,,,,,,,,,,,,, I have an 02 ZO6. A buddy of mine told me that the car looks a LOT better with that DAMN rear deck emblem removed.
Thought for sure that there would be HOLES for pins. NOPE. Used the WD-40, heat gun and fishing line. GONE and NEVER looked back!
YES,,,,,, the car does look a LOT better without the emblem!
YES, there are holes in the front bumper for the alignment pins>
02 Z WITHOUT EMBLEM!
WITH AN EMBLEM!
I also installed the rubber seals for the hood/fender to the rear trunk lid opening to help keep out dirt!
To front emblem removal?
