C-5 1999. When you start it up the Top hose goes flat. By opening the surge tank cap you can hear hissing of air & the hose opens up. Until it gets cold again, Thank's Gentleman. I Appreciate, Helping a friend. Gene from C-3 ..
Hey Gene! It's been a while since i was on the C3 forum. We traded parts a few times.
It sounds like time for some routine maintenance. Replace the hose and t'stat. Bleeding the air out of the system afterwards is a bear so there are specific steps to doing that. I'm sure someone else will chime in on that.
Seen this DOZENS of times... All that's wrong is you have a DEFECTIVE PRESSURE CAP on the coolant reservoir.
There's a NEW UP-DATED 18 lb cap and its not expensive.
Yours has a plugged relief valve . It should allow AIR IN the cap when the cooling system cools down and NOT allow pressure OUT when its HOT. If its working properly, the TOP HOSE will not collapse!!
[QUOTE=Bill Curlee;1591821869]Seen this DOZENS of times... All that's wrong is you have a DEFECTIVE PRESSURE CAP on the coolant reservoir.
Simple as that!
I agree. I had the same issue and a new cap did the trick
