transmission
Old Mar 25, 2016 | 09:09 AM
madmama's Avatar
madmama
3rd Gear
Default transmission
My c5 doesnt want to shift gears when im driving. There is fluid in it it
Old Mar 25, 2016 | 09:29 AM
Macleod52's Avatar
Macleod52
You need to help us out a little. You really didn't give us anything to go on. What year is your car? Is it an auto or a manual? Any symptoms up to this point? When is the last time the transmission/clutch fluid was changed? How many miles are on the car?
Old Mar 25, 2016 | 09:52 AM
madmama's Avatar
madmama
3rd Gear
It is a 99. Its automatic trans. I had transmission fluid checked yesterday. Its is full.
Only symptom iit had or has it seems like it may be slipping. The dash says now the transmission is overheating. I could use all advice i can get. Can i trouble shoot it before i say the transmission is screwed and cry.
Old Mar 25, 2016 | 10:41 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
if the clutches are slipping it would cause the trans to overheat, might need a overhaul ???
Old Mar 25, 2016 | 12:07 PM
Macleod52's Avatar
Macleod52
Is it possible that old dirty fluid could cause the issues/symptoms? The mileage wasn't specified and neither was the last time the fluid was changed. Just because there's fluid doesn't mean it's not dirty and no longer doing it's job. I'm no transmission expert but if it's the original fluid then it's 10 years overdue for a flush.
Old Mar 25, 2016 | 02:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have to ask this question and I would like you to be VERY SPECIFIC on the answer.....
HOW did "THEY" check the fluid level?????? Did they uses a dip stick, put the car on the lift and pull the plug..
PLEASE fill us in on the highlights..
Im not trying to be a smart ***. I THINK you may NOT be getting the FULL CORRECT TRUTHFUL ANSWER.
To PROPERLY check the A4 fluid level, the engine MUST be running and at full operation temp (ON A LIFT) The FILL plug is removed (engine running) " you should envision HOT CRAMPED conditions" and the ATF should be full to the very TOP of the fill port.
IF,, the plug is removed (engine OFF) approx. 2+ qts of fluid will GUSH out and can NOT be replaced until the engine is running.
NEXT... WHAT DTCs are being displayed?? That will help diagnose the issues.
WHAT GEARS DO YOU HAVE?? What GEARS ARE NOT PERFORMING WELL??
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Mar 25, 2016 | 02:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some interesting reading... Just as I was explaining about reading the fluid level::
https://www.corvetteforum.com/forums...el-stupid.html
To transmission
