Differential swap help
Old Jun 12, 2016 | 10:42 PM
Ryan Rogers's Avatar
Ryan Rogers
1st Gear
Default Differential swap help
So I have a 1998 corvette auto and want to swap it to a z06 342 differential.. if I order the entire dif will it be direct bolt on? Or do I need additional parts? Any help is much appreciated! 😃
Old Jun 12, 2016 | 10:52 PM
feeder82's Avatar
feeder82
Bolt right in, you will need to have the pcm tuned.
Old Apr 1, 2017 | 07:53 PM
harrykerry's Avatar
harrykerry
Default Diff swap
Im doing the same thing next week or so, let me know how yours goes. I understand the o rings should be changed, but GMparts said not available? Do you know where to get them?
Old Apr 2, 2017 | 07:08 PM
Patches's Avatar
Patches
As I mentioned in a similar thread here, you'll need to transfer the A4 diff adapter plate from the old to the new diff.
Here's the adapter plate I transferred from my 2.73 diff to my 3.42 diff a few years ago. It's held in essentially by the O-ring so it's not pressed in with a lot of force. You should replace the large, outer O-ring and shaft seal while it's out.
This is the large seal plate O-ring at Cultrag. Good idea to have a spare incase yours is trashed during the swap.
http://www.cultragfactoryparts.com/oe-gm/12369456
This is the shaft seal.
Old Apr 2, 2017 | 08:02 PM
vettenuts's Avatar
vettenuts
Most don't replace, but the service manual calls for new cradle nuts as well. I replace mine when I remove the cradle, many don't.
Old Apr 4, 2017 | 11:55 PM
jim993's Avatar
jim993
Keep in mind the point by feeder82, if you don't get the PCM reprogrammed, shift points will not be right, most noticeable at full throttle.
I am thinking that 3.42 was not a factory option for the A4 and if that is the case, a dealer will not have the reprogram available. You would have to go to a shop that has the knowhow to create new shift points at part and full throttle.
In my case, for a new 3.73 gear set, A&A Corvette in Oxnard CA got the job done.
Old Apr 5, 2017 | 10:28 AM
harrykerry's Avatar
harrykerry
Default 3.42
Thanks alot, I found a sharp mechanic that thinks the Hypertech tuner would do the job, now Im having second thoughts. I think I need to find a shop, hopefully much closer than AA, although, I know there great.
Got any ideas of a shop in northern Ca, like Redding,
Chico or even Sacramento?
Old Apr 5, 2017 | 10:46 AM
harrykerry's Avatar
harrykerry
Default ECS Mail order tuning
I just got off the phone with Doug at ESC mail order tuning, I think thats the way to go for me...
Old Apr 5, 2017 | 12:33 PM
Antz97znj's Avatar
Antz97znj
I bought a used 342 diff. off of Ebay for $200 and freshened it up w/ new seals,fluids,etc.
Old Apr 5, 2017 | 03:04 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I agree completely!
Good speaking with you.
Old Apr 14, 2017 | 11:39 PM
harrykerry's Avatar
harrykerry
Default 3.42 Gear Swap
I am happy to say that I have a unique 1998 A4 with a 3.42 Z06 differential..Thanks to Doug at ECS for great work and a quick turnaround. And Tony at Action Axle in Redding, Ca for a great job! Oh, and its frickn badazz!
To Differential swap help
