Wish i saw this when i did my cam instal. My car is a 2003 z. I used a Romac balancer with ARP bolt, but did not pin it. What is pining a harmonic balancer and why would one do this?
My holes seem centered. Do they need to be tapped?
Wouldn't Teflon be a great material to use?
The LS crank shaft is not keyed and the harmonic balancer has the potential to spin on the shaft. "Pinning" is basically like a key and ensures the balancer and the shaft spin together.
If your block has the holes, they are already tapped. m8x1.25x35
"I get a lot of questions about the dampener rubbing the chain on the driver side. I wanted to post up here to try and answer the question for as broad of an audience as possible"
I bought one of these but have not installed it. I did find a pic of the UNAVAILABLE GM unit:
Notice in the GM design, the bolt holes are not symmetric with the dampener; the right bolt is located further to the right edge and lower than the left bolt location. This would move the center of the dampener slightly to the left away from the drivers side and rotate the right top closer to the cam gear.
I am not sure if this is of any significance at all and it might be in the same mounting position as the GM design. It would be great to hear from some people who have installed it, put on some miles, and then inspected it. Experience counts. I would really like to have the benefits of a dampener in my engine.
If you look at the drawing for the hole locations, they are not centered either. See the drilling template below.
So the GM dampener design has offset bolt locations to reverse match the non-symmetric offset holes in the block. Case of two wrongs making a right! Maybe GM had to space the holes non symmetric to not interfere with a cavity in the block. Really want to hear from someone who has inspected it after installing it and putting on some miles.
A little hard to tell from the pics, but it appears with the new unit installed in a block that the curvature of the dampener does not match the curvature of the cam gear, i.e. the drivers top is lower than the passengers relative to the cam gear?
If you look at the photo in Georgies post you can see the holes are in the center of each boss, but skewed to the right of centerline. Here is my GMPP damper installed, where the final location does appear centered. Note that this installation was using the Katech C5R timing chain on stock gears.
There was a small bit of slop in the chain, I wouldn't put too much stock in the gap that is in the photo since it's not rotating. Once I started moving it that slop went away as I recall. The damper is there to prevent chain wrap on the opposite side (passenger side) as the system is spinning. Chain wrap is the main cause of failure.
How much do you think the relation of the centerlines of the cam/crank increase? Why wouldnt one make a dampner that get rid on the outside of the chain? Dont know if that makes sense lol
Because it is NOT A Tensioner.. It's just there to prevent wrap around when racing and shifting gears.. More prevalent on a stick car vs an automatic..
There is one other critical factor for a damper to perform its job correctly and that is the interference fit. As part of installation, you are supposed to measure the crank snout and hub internal diameter. If the interference fit does not fall within the given tolerance, the hub is supposed to be honed to obtain the correct interference fit. This is provided in the ATI and Innovators West instructions and other aftermarket dampers.
I have 20 plus thousand miles on my LS2 chain, GM chain dampener and powerbond harmonic dampener. ZERO issues. I run the engine hard.
A new chain will have some slack (as designed) If you rotate the engine in a CCW or CW direction, there will be some slack (space between the chain and chain dampener on one side or the other.
As others have stated, the dampener is designed to PREVENT chain wrap during hard engine acceleration or hard deceleration.
I made that video for you guys the other day. Very impressed with the product. I'm no pro youtuber but I like to make a video for products where there are none.
18-20 foot pounds with some blue loctite. It will not go anywhere.
I know it's been two months, but can you give me a little insight on the oil pump o'ring? From what I've read I have to make sure it goes on correct and also it doesn't fall into the pan. My FSM shows the task with the oil pan off. Thanks Mike
Unfortunately I don't remember the oring details perfectly. The Melling instructions if you use a Melling pump are quite specific and clear on which oring to use with which pick up tube you have to the point where it's a no brainer.
