HELP Code PO300
Old Jun 22, 2016 | 11:06 AM
Dave4Vettes's Avatar
Dave4Vettes
Cruising
Default HELP Code PO300
I have a 2003 coupe automatic with 9997 miles. I've have had no problems with the car but we went out to dinner and pulled into parking spot and it stumbled (never had this before). It set diagnostic code PO300 and now continuously miss fires on #8 cylinder I cleared the code and it still miss fires and it resets code PO300. I checked each cylinder spark with a clamp-on timing light and I get no light on #8 but all other cylinders firing OK. I traded ignition coils #8 and #4 and still no spark on #8 but #4 is OK. I checked fuel rail pressure 59 psi. I checked ohms on injectors and got 14.2. I pulled spark plug and plug wires and they are OK.
Any suggestions will be helpful.
Old Jun 22, 2016 | 12:13 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
Only thing left is to swap plug wires and plugs
Old Jun 22, 2016 | 12:26 PM
Dave4Vettes
Cruising
I already checked plug wires and plugs. Thanks
Old Jun 22, 2016 | 12:37 PM
v6turbo87's Avatar
v6turbo87
Check the wiring going to the #8 coil?
Old Jun 22, 2016 | 12:43 PM
Dave4Vettes
Cruising
I have already done that. Thanks
Old Jun 22, 2016 | 01:41 PM
73Corvette's Avatar
73Corvette
Crank Sensor? Ground G107 Left rear head
Old Jun 22, 2016 | 02:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the other cylinders are firing, it cant be a CRANK SENSOR.
Here is a schematic for the coil. You need to check coil POWER, Ground, signal hi and low. Don't guess,,,, Use a METER!
Also examine the connectors for the coil harness and the bank connector on the coil mount bracket. Look for damaged wires, female wire connectors ect. The harness that runs down the drivers side of the engine bends around a metal bracket. Look at that area for damaged wires/harness!
Old Jun 22, 2016 | 03:01 PM
73Corvette's Avatar
73Corvette
[QUOTE=Bill Curlee;1592478541]If the other cylinders are firing, it cant be a CRANK SENSOR.
Thank you Mr Curlee
Old Jun 22, 2016 | 03:22 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Signal HI is the IGNITION CONTROLLED signal from the PCM that actually FIRES the coil! ... IF,,,,,,,,,,,,,,,, you have access to an old POINTS DWELL METER, you can actually read that signal! Or you can use an O Scope!
Just compare the readings from a known good working cylinder to #8 and the FAULT should jump right out!
NOTE! The ignition circuit wires are know to have damaged insulation!
Bill
Old Jun 22, 2016 | 05:06 PM
rrwirsi's Avatar
rrwirsi
[QUOTE=73Corvette;1592478648]
Thank you Mr Curlee
I never knew anything about a crank sensor until my wife's 2004 Murano just quick running while she was driving. Luckily she was in the Right lane was able to pull over. After the car was dropped off by the tow truck to the repair shop, it started. The repair shop tried to get the car to duplicate the problem for 2 days. No luck. The internet suggested fuel pump OR crank sensor as a cause. But there were no hard codes posted by the computer. I decided on replacing the sensor ($250) vs the fuel pump ($1200). After 6 weeks of driving no repeat. So far so good.
Old Jun 22, 2016 | 07:07 PM
Dave4Vettes
Cruising
I've done that also. Thanks
Old Jun 22, 2016 | 08:05 PM
Dave4Vettes
Cruising
[QUOTE=rrwirsi;1592479528]
The car always starts and continues to rum but misses on cyl #8 so I don't think it would be a crank sensor or it wouldn't start. Thanks
Old Jun 22, 2016 | 08:09 PM
Dave4Vettes
Cruising
Bill
I no longer have a dwell meter so looking for one. I assume when I get one connect red between the coil trigger/control wire and black to ground. I have a oscope but haven't used it for years and then not for cars. How would it be connected and oscope switches selected.
Old Jun 22, 2016 | 08:12 PM
Dave4Vettes
Cruising
Bill
I think I'm down to either wires and I see nothing and the car only has 9997 miles or PCM and I don't know of a DIY method check the PCM.
Old Jun 22, 2016 | 08:41 PM
feeder82's Avatar
feeder82
pull the valve cover and check the springs
Old Jun 22, 2016 | 09:26 PM
73Corvette's Avatar
73Corvette
that wouldn't keep him from NOT getting fire to #8 cylinder...
Old Jun 22, 2016 | 09:44 PM
Dave4Vettes
Cruising
I agree here. Thx
To HELP Code PO300
Old Jun 23, 2016 | 06:29 AM
vettenuts's Avatar
vettenuts
Just curious if you swapped out the #8 plug as well as the wire? Know someone who had a misfire issue with relatively new plugs and it turned out to be the plug in the end even though when he looked at it he couldn't see an issue. If you haven't done it, might swap #8 and #6 and see if the miss follows the plug.
Old Jun 23, 2016 | 08:41 PM
Dave4Vettes
Cruising
Well thanks to all who helped. I had removed the plugs and wires but when I installed the I reversed the wire but not the plug so to not make too many changes all at once but at your insistence I did go back today and switch and behold the miss moved. So a new plug later all is well. I all my many years I've had weak plug, ignition, etc. foul a plug but never one that wouldn't fire the timing light. Thanks again.
Old Jun 23, 2016 | 09:27 PM
73Corvette's Avatar
73Corvette
Good call vettenuts...
Glad you got it figured out and running smoooooth... thanks for posting your outcome... very important for future readers of this thread
