02 sensor issue
Old Jul 9, 2016 | 12:29 AM
JAKE-SON's Avatar
JAKE-SON
Default 02 sensor issue
Both my o2 sensors threw codes of p134 and p15x of no activity,usually happens right after warm up when it tries to go closed loop. I can clear the code and get it working and it can go days without a issue and then it can happen every time I start, random issue. I replaced the o2 sensors, didn't seem to work, checked under the hood for the fuses and found the fuse had popped. Replaced it, issue went away for a few days, but has resurfaced. I have went under to check wires and there are o issues, however I do see this.
Driver side
This is what it is on the passenger
Unburnt
I don't know what this is , or if it causing the issue.
Ryan
Old Jul 9, 2016 | 06:13 PM
oelarse's Avatar
oelarse
This is how the left and right front O2 sensor and it connector should look like .On your first photo it seems like something has melted .
Which fuse popped?
DTC P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1 indicates
problems with front O2 sensor drivers side .
left sensor
right sensor
Old Jul 9, 2016 | 08:33 PM
midnight01's Avatar
midnight01
Driver side
Unburnt
Ryan
those look like your rear O2 sensor plugs, obviously both are not connected at all. Check to see if your ground wire is still attached, on the driver side is a pretty thick ground that attaches to the engine, that is the ground for the o2 sensors. With the looks of that melted plug, you might have a missing ground causing the issue.
Old Jul 9, 2016 | 09:37 PM
JAKE-SON's Avatar
JAKE-SON
The rears have been deleted, but my ground wire on the drivers side it burned through and frayed, didn't think much of it. But if that's for o2 sensor then that's my problem. And the o2 sensor fuse under the hood is the one the melted
Old Jul 9, 2016 | 09:41 PM
midnight01's Avatar
midnight01
There you go, get the ground wire fixed and then see what's happening.
Old Jul 9, 2016 | 10:43 PM
JAKE-SON's Avatar
JAKE-SON
Default ....
Which fuse popped?
left sensor
right sensor
Do you have a close up on where your ground strap goes, mine is burned through and I dont see the end that's none frame side
Old Jul 9, 2016 | 10:45 PM
JAKE-SON's Avatar
JAKE-SON
Which fuse popped?
left sensor
right sensor
Any pics on where ground wire goes, all I have is the end where it connects to frame
Old Jul 10, 2016 | 06:37 AM
oelarse's Avatar
oelarse
The O2 sensors groundleads are spliced together with fuelpumpe relay and engine oil sensor in a splicepack SP122 . This splicepack is connected to groundpoint G105 (engine ground).
Here is another thread showing more info and pictures of this splicepack SP122
https://www.corvetteforum.com/forums...on-needed.html
Old Jul 17, 2016 | 09:23 PM
JAKE-SON's Avatar
JAKE-SON
I replaced the ground strap but still getting the codes intermittently. Car runs fine for the most part except this issue.
I just found a wire off gs104 was cut so I'm not routing it to the battery negative
Ryan
Old Jul 19, 2016 | 02:39 AM
JAKE-SON's Avatar
JAKE-SON
Ryan
Ugh, still getting the codes
Old Jul 19, 2016 | 02:40 AM
JAKE-SON's Avatar
JAKE-SON
Where is sp122 exactly any pictures?
Old Jul 19, 2016 | 02:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Behind the battery and its taped to a large wiring harness. Its a small square plastic box that looks exactly like a ground connector (ie G-101 or G-102) but without the metal grounding tab.
Old Apr 1, 2018 | 02:51 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Thanks for this info will do some research on mine and see if its the same I got the P0134 CODE
To 02 sensor issue
