I'm trying to install my new damper. I pinned the crank, got the damper on I think all the way. Now I am using the old bolt to torque it to 240ft lbs.
The problem is that to remove my starter I would need to cut the crossover/up pipe for my turbo(po ran it that way)
I tried using a nylon strap wrench on the hub and the helped some but I still can't get enough torque. I cut the old serpentine belt and tried using that but still not enough.
Would i be able to use the inspection cover on the bell housing and block the flex plate from spinning. I know the torque tube sees plenty of torque anyway, I just don't want to mess anything up
The tool that is used locks into the flex plate through the starter opening. I personally wouldn't jam a screwdriver or something in there.
Do you have the actual GM tool or something like that? You might be able to make a jig to hold the tool to the bell housing cover bolts to hold the tool.
Here is a tool available at Autozone, not sure if it can be rented but you might be able to adapt it: Flywheel Locking Tool
One other option, if you have some help, would be to use a flywheel turning tool and lock it on and against the ground or have a helper hold it. Just not sure that tool will take the torque applied as it is not real robust in its construction.
I'm trying to avoid taking the starter out.all those tools from my understanding have to go in where the starter is. I didn't think you could get to the teeth of the flexplate from the inspection cover.
I am thinking about grabbing the slip joint connector with an adjustable or an open end wrench
Remove the flywheel inspection cover and have a friend hold a large screw driver in the teeth. Worked great for me. Really any random piece of metal you can stick in there will work. the longer the better as it will give you more leverage, but you don't really need that much.
I have a good 12" strap wrench, but it wouldn't get a good enough grip on the hub of the ATI. I can try putting the other pulley on and putting the strap wrench on that.
I like that belt idea, that looks like it will grab really well.
You can use the old OEM bolt to properly SEAT the damper back onto the hub!
You should NEVER use the old or new OEM bolt to start the damper on to the hub!!! The OEM bolt is TOO SHORT and can RIP OUT or damage the first few threads in the crank snout!
NOTE. If you heat the damper HUB (the CENTER PART that slips onto the crank snout) up to approx. 150-200 deg, the damper will go on a whole lot easier.
Holding the damper to properly TORQUE the NEW One Time Use Torque to yield bolt OR torqueing the ARP Bolt can be an issue. Like I stated, my strap wrench worked fantastic!
BC
Flywheel holding tool was like 15$ on ebay but I did have to pull the starter. It's only 2 bolts and 2 nuts for the cables hooked to it, I believe you can pull it without removing the header.
Doesn't the automatic also have the plastic fillers on each side of the engine at the front of the bellhousing? If so, take the one off the passenger side and use a pry bar against the flexplate teeth.
