corvettegt
Old Aug 1, 2016 | 04:12 PM
corvettegt's Avatar
corvettegt
Default corvettegt
2000 corvette where is the fuel filter? and how do I clean my fuel injection?
Old Aug 1, 2016 | 06:26 PM
corvettegt's Avatar
corvettegt
Default corvettegt
Originally Posted by 8VETTE7
Fuel filter is mounted on the inside facing part of the frame just forward of the drivers side rear tire.
Why do you think the fuel system needs cleaning?
I don't get the gas mileage I use to get it was 30mpg now 27mpg
G.T.
Old Aug 1, 2016 | 06:55 PM
Have your driving habits changed? What about more traffic, less open highway driving, different road conditions (more hills)?
When were your plugs and wires last changed?
Could be a number of things affecting your MPG.
Old Aug 1, 2016 | 07:31 PM
Smoken1's Avatar
Smoken1
When was the last time you changed your air filter?
Old Aug 2, 2016 | 06:48 AM
runner140*'s Avatar
runner140*
AND cleaning EVERYTHING back of the air filter.
Old Aug 2, 2016 | 10:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I SERIOUSLY doubt that changing the fuel filter will change the fuel mileage at all. You will notice a dirty / congested fuel filter at WOT or heavy load conditions when the engine has a distinct loss of power.
There are a whole list of things to check/clean/change that has an effect on fuel mileage:
Air Filter?
MAF dirty?
Throttle Body Blade and opening dirty?
O2 Sensors working properly (correctly cycling)
No vacuum leaks
No leaks between the MAF and TB (air bridge)
Defective engine sensor: MAP, MAF, ATS, CTS, etc.....
Plugs and Wires condition
dragging a brake pad/pads
Low Tire pressure
Yes, a dirty fuel injector/s can and will cause poor fuel economy. Run a few treatments of Chevron Techron and a couple tank full of fuel.
Bill
To corvettegt
