When the length checker is at 7.200 (8 turns) I have a little vertical play.
I turn the checker another half to 8.5 (I have to remove it every time, I can't get my fingers in there) to 7.225 and there is no longer a "click" when I pull up and down, but it does allow side to side movement.
Assuming a .075-ish preload for LS7 lifters, I should be looking for 7.300 push rods. This seems way short. I thought TSP used a smaller base circle and I would need longer push rods.
Any idea what I could be doing wrong?
Also, I did this with both the intake and exhaust. Turned the engine over by hand a couple times and nothing changes. I'm reading you need .050" short pushrods for higher cup on the LS7 lifters, but where would I be losing the other .050"?
Smaller base circle requires longer pushrod because the lifter is now sitting lower in the bore and the rocker hasn't moved relative to the head but the head has move lower due to the gasket. One thing to be very careful of with new lifters is that when you measure the plunger doesn't depress at all. Not sure on the LS7 lifters, but my Morels were very easy to depress the plunger when they were empty so measuring was tedious.
When I installed the TSP 228R cam I also ended up with shorter pushrods than stock. TSP said not to worry about it and trust the length checker. They suggested that possibly GM may be using a different amount of preload.
Four years and many HPDE's later and it still going strong!
