Hurst Install - Finished - Not Thrilled
I am going to tear it apart tomorrow and see if I can make it better.
As SOON as I started the car, I noticed a great deal more engine noise. I assume this is because the closeout boot doesn't fit as well?
I am going to get some dynamat or some kind of insulation in there to try and deaden the noise. Heck, I'd stuff it with WASHRAGS if I thought they wouldn't catch on fire...
Anyone else done anything like this?
Shifting is tight, but short. I'm going to pull the springs and lighten them up tomorrow. Overall, shifting is good - that is not my problem. However, as I pulled back into the garage tonight, I ran over one of my loose springs - so I'll have to be creative in loosening it up.
My other problem is the shifter rattling. NOISY. Almost never quiet. I can't really see me keeping this shifter installed at this point.
I love the way it shifts, but I don't want the noise. My car is sounding like a 73 Nova stripped to the sheet metal for drag racing instead of a 50k supercar!
I had a Hurst on my 93 Cobra Mustang and it only rattled at WOT near the top of the rpm range. I considered the Hurst one of the best mods I ever made on that car, for day to day enjoyment.
I don't feel that way about the C5 billet shifter right now.
The rattling. Which **** do you have on? I have tried different ***** on my Ripper. Just put on a Momo, and now I know why most guys report they don't vibrate. A rubber "sleeve" goes over the top of the shifter that the **** then slides down over. It is because they are a universal fit (not threaded). I had been against a Momo because I always thought I wanted a **** that threaded on. But now I think the rubber sleeve is what keeps it from vibrating
Thanks for your thoughts and input.
Jim
[Modified by jschindler, 8:59 PM 9/19/2002]
Did you tighten the shifter down to 10lbs of torque? Did you adjust the stops? Perhaps that's where your noise is coming from?
But like racer44 said Most of us enjoy a precise shifting shifter I love mine ...... maybe recheck the install :confused:
RAY
Good suggestion, I will try it - but I think the (STOCK) shifter **** is on pretty well. I tightened it down pretty good and then went on around tighter until the demon key lined up
I expected a little rattle under WOT, but nothing like this.
You never know I guess. The majority of the world thought that the earth was flat once... However, until today I would have fit into the majority of folks who thought the Hurst was golden.
I do recall one post here from a tuner that said he had three re-installs of the stocker scheduled. All I know is that I have experience with Hurst shifters and I have never had this much noise from one. I'll work with it today and see what happens...
Try a new ****. Good luck.
Tom
USAF Retired
:cheers:
It gets VERY loud. I love it. :smash:
Pictured here, though kinda hard to see:
[Modified by Lumberjack Nate, 1:44 PM 9/20/2002]
[Modified by Lumberjack Nate, 1:45 PM 9/20/2002]
I'll let you all know how it turns out...
