More than just a bad remote
Old Feb 3, 2017 | 12:06 AM
xdmikey's Avatar
xdmikey
Default More than just a bad remote
Several months ago I locked my '97 using the fob but when I tried to disarm it I couldnt. I had to unlock it with the key and of course the horn sounded for 10 or 12 seconds then stopped.
I never did that again until maybe a month later my son and I went to a football game where I locked it again and went through the same thing.
Three weeks ago my battery failed so I picked up another red top and thought all would be good.
I drove 10 miles or so to get a book and tried to arm it at the bookstore. No go. I started messing with it when I got home and haven't gotten anywhere. I read all the posts to relearn, and synch but nothing works.
My fob is less than a year old.
Any ideas where to go next? I thought the fob would relearn due to the new battery.
Old Feb 3, 2017 | 07:10 AM
vettenuts's Avatar
vettenuts
One other place to look. I had numerous issues with my other GM FOB that is similar to my Corvette FOB and even bought a new case and put in my original circuit board. Ended up being bad solder joints on the battery holder. Since I fixed that I haven't had a single issue.
Old Feb 3, 2017 | 07:56 AM
xdmikey's Avatar
xdmikey
Default Thanks 8VETTE7
The fob doesn't work at all anymore.
I don't think there is a correlation between the new red top battery and my fob issue.
Old Feb 3, 2017 | 08:00 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
bad raf module ??? tire sensors work ??
Old Feb 3, 2017 | 10:06 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CODES are the very first thing to do.
Then a successful relearn for ALL the fobs that you have.
If you cant get a successful relearn, something is wrong.
Bill
Old Feb 3, 2017 | 10:59 AM
xdmikey's Avatar
xdmikey
I'll get codes here shortly.
Old Feb 3, 2017 | 11:24 AM
xdmikey's Avatar
xdmikey
BO-RFA NO CODES
I take it this isn't good.
The rest of the codes are:
10 PCM no codes
28 TCS 2 codes
38 RTD no comm
40 BCM no codes
60 IPC 1 code
80 RADIO no comm
99 HVAC 2 codes
A0-LDCM 3 codes
A1-RDCM 3 codes
A6-SCM 2 codes
BO-RFA no codes
Old Feb 3, 2017 | 11:40 AM
xdmikey's Avatar
xdmikey
Thanks Pounder, I missed you earlier.
TPMS work somewhat. They tell me I have low pressure in the tires but with the temp change here all my cars with TPMS say that for a bit but the vette has always said it. I had an oil change done an they topped off the air and it was good for a while but now we have hot/cold daily changes so im not sure. The vette is a very rare driver: two kids, two boyfriends, one wife always working so: rare driver.
Old Feb 3, 2017 | 12:17 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
they use the same raf signal, that's why I asked, so you could maybe count that out. I changed mine out with the updated system which works better, but pricy !!
https://www.corvetteforum.com/forums...rformance.html
Old Feb 3, 2017 | 01:50 PM
xdmikey's Avatar
xdmikey
It looks to be:
A0-LDCM B2282 H
B2284 H
U1064 H
A1-RDCM B2283 H
B2285 H
U1064 H
A6-SCM B0851 H
U1064 H
I believe I got this right.
Thoughts?
Old Feb 3, 2017 | 03:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
You didn't provide the specifics about the TCS or IPC codes.
All the Bxxxx code that you listed are most likely the result of a low or weak battery. You mention that the car is not driven often. Do you keep the car connected to a battery tender during periods of sitting in the garage?? You might consider doing that when the car won't be driven for more than a week or two. The battery on a C5 will slowly drain during longer periods of not being driven and not having a nearly fully charged battery when you go to start the car can be hard on the electronics in the car. Many sensors go through initialization and/or calibration when the key is turned to ON and BEFORE the engine is running and the alternator trying to recharge the battery. If the voltage is low those diagnostics and calibrations can fail and set codes or worse yet cause relays to fry because of low voltage levels. The car may start fine because the starter requires a large current which can be produced even by low voltage. Most electronics are voltage sensitive and do not require large currents and can fail/perform at reduced levels if the voltage is low. Once the car starts having voltage from the alternator is too late for these types of sensors.
Getting back to your FOB issue, if there are no codes for the B0 - RFA and NONE of the buttons on the FOB work then something has happened to the FOB. Here is a common failure on the early year FOB's:
http://forums.corvetteforum.com/c5-t...em-solved.html
You may need a magnifying glass to carefully examinr the board for the FOB for cracked solder joints. Also the holder for the battery is known to break............
You could NOT be getting better guidance form ANYONE!
FOLLOW IT.
However, you have NOT confirmed that you have properly tried to RETRAIN YOUR FOBS and if they TRAINED SUCCESSFULLY.
Try to retrain them and report the results.
LOL! "BO-RFA NO CODES" is the GOLD STANDARD!
Thats what ALL of the modules should report, if they are properly working.
if YOU HAD A BO-RFA NO COMMUNICATIONS,,, Now that would be bad because the module either isn't working or able to communicate with all the other modules on the serial data line.
HVAC 2 codes 2 codes means that there are TWO separate DTCs that you need to use the buttons on the IPC to further EXPAND and show those DTCs EXAMPLE B0361 & B0332
CLEAR ALL THE CODES and then,,,,,,,,,,,,,, report what comes back.
YES. A weak or defective battery will set a **** load of DTCs! They mean nothing other than the electrical system was NOT happy because some of the modules shut down on low voltages like they were designed to do if the supply voltages drops below 8.5 VDC .
Old Feb 3, 2017 | 03:38 PM
xdmikey's Avatar
xdmikey
Thanks 8VETTE7 & Bill.
I have not driven Ives much since I put in my new battery so I'll tell the wife " I got to drive the car right now!"
then pull ill all the codes again?
it's Friday night so at least one girl will be out while the other one's boyfriend is working so he can hang with us on Sunday.
I may not post up for a couple days until I get my facts in order.
I appreciate your your patience with me.
Old Feb 3, 2017 | 03:44 PM
cbell3186's Avatar
cbell3186
xdmikey, put a tender on that redtop. I have killed 3 of them already without them and have had to reprogram my fob countless times because of the low voltage.
Old Feb 3, 2017 | 05:05 PM
xdmikey's Avatar
xdmikey
Default My battery tender
My battery tender
Old Feb 3, 2017 | 07:31 PM
xdmikey's Avatar
xdmikey
Default 1.5hrs later
After tear assing around my little town I got:
60 IPC B1543 H
Oil Temperature Circuit Open
But it's an H so?
I tried to do the seven second hold both buttons, to no avail so a little later I'll try the thing in the car again but I'm thinking the remote needs work, since so many people have had to do it.
Old Feb 3, 2017 | 08:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
60 IPC B1543 H
But it's an H so?
QUOTE"
"I tried to do the seven second hold both buttons, to no avail
Thats called a SYNC PROCEDURE
THIS,,,,, Is what you need to do:
http://www.corvetteactioncenter.com/...ansmitter.html
BC
Old Feb 3, 2017 | 11:11 PM
xdmikey's Avatar
xdmikey
Default Thanks again Bill
Should I not worry about the oil temp circuit open?
And yes, I'll try the synch procedure in the morning and report back.
Old Feb 6, 2017 | 08:38 PM
xdmikey's Avatar
xdmikey
Default Success at last
I did the synch with a new battery, as I was about to perform the relearn!
Thanks a million corvetteforum!
Old Feb 7, 2017 | 10:09 PM
xdmikey's Avatar
xdmikey
Actually both.
Already had the new red top but put in a new fob battery. Also, I've had my ride on a tender since the battery installation. And it will stay on it.
To More than just a bad remote
