1999 Convertible hatch button does not work
Old Aug 9, 2017 | 11:12 PM
jd911's Avatar
jd911
For what it's worth here's the troubleshooting guide. some of them use a test light or a meter, it might help.
Old Aug 9, 2017 | 11:21 PM
jd911's Avatar
jd911
Here's the System Check the procedure refers to which isn't much more than you've already done.
Old Aug 10, 2017 | 12:40 AM
pjdbm's Avatar
pjdbm
thanks a million for all this! I will go back at it on Sunday most likely.
Old Aug 11, 2017 | 08:44 PM
T_Vert's Avatar
T_Vert
I also think E brake must be on? Could be wrong.
Old Mar 30, 2019 | 07:56 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Phil, this is the wiring for your roof !!
Old Mar 30, 2019 | 08:10 PM
pjdbm's Avatar
pjdbm
Rob,
I will check 87 & 30 grds tomorrow with power from battery, I physically pulled the fuse 17 and checked it with a meter and it was good. What can cause lost voltage at 86 & 85?
Thanks for helping with this
Old Jan 14, 2023 | 04:51 PM
pjdbm's Avatar
pjdbm
This might be the longest problem that was found in forum history but I chased this again after putting it on the shelf for years.
It turned out to be the fuse box, at one point before I took ownership, this fuse box was hit with some water.
The bottom part of the fuse box was corroded and a wire had broken lose.
I need a new fuse box and I am currently cleaning all the wiring.
The tonneau relay and the fuse was in the area that was corroded.
Thank you JD911 and C5Diag for inspiring me after 4 years??
I knew right away that this was my issue when I saw the black bottom cover, covered with rust and oxidation from copper wires.
The orange wire was totally lose and missing the terminal pin when I pulled this bottom connector, I ordered a used harness with connectors and pins complete and I will take out the same color wire and will re pin it, splice it in, solder & and heat shrink it.
Here is the fuse box and the damage that was done to the pins
You can see the pins clearly deteriorated, I could not use this box and purchased a used one, waiting for it to come in.
The pin that was in the worst condition was the one that was connected relay 41 (TONN REL)
Old Jan 14, 2023 | 05:08 PM
C5 Diag's Avatar
C5 Diag
Glad you found it !!…better late than never…LOL
Old Jan 14, 2023 | 05:18 PM
sonicss33's Avatar
sonicss33
Also, be sure to check, clean the udders which may have caused the water issue years ago.
Old Jan 14, 2023 | 05:24 PM
pjdbm's Avatar
pjdbm
He Rob, where would I be able to get a terminal from? I have to replace one and splice the wire back in.
TIA
Old Jan 14, 2023 | 05:25 PM
pjdbm's Avatar
pjdbm
Yes, this was done shortly after ownership and thanks to this forum.
This tonneau button was the only issue this car had
Old Jan 25, 2023 | 02:02 PM
C5 Diag's Avatar
C5 Diag
TIA
Amazon !!
Old Jan 25, 2023 | 02:04 PM
  #33
pjdbm's Avatar
pjdbm
Updated:
I installed a used fuse box that I obtained, I also repaired an orange wire that was broken loose and thought that this would be fixed.
The hatch button still does not work.
*I do have voltage now at the fuse #17 as well as the relay #41 that I did not have with the damaged fuse box.
*No DIC codes with old or new fuse box
*Everything in the car works as it should except for this tonneau button and circuit.
The manual asks for scanner to diagnose switch signals, I don't have that scanner.
I am not getting voltage to the tonneau button nor the latch ajar connector.
I feel I am half way there but concerned that perhaps the water intrusion did more damage to perhaps the BCM??
Also, because of the damage to the fuse box, I am thinking my issues are by the IP area and not downstream by the latch and button.
Old Jan 25, 2023 | 03:41 PM
  #34
pjdbm's Avatar
pjdbm
Amazon !!
Thanks, I ended up buying a complete IP fuse box harness, used. I paid about the same and I got to see how the pins fit and get removed.
Old Jan 25, 2023 | 05:19 PM
  #35
Dads2kconvertible's Avatar
Dads2kconvertible
Given the corrosion in the old fuse box have you checked under the battery tray to see if it maybe had one of those early batteries that cracked and leaked acid on the component under the tray?
How much of that corroded harness did you replace? Is it possible some corrosion wicked up the copper wire inside the insulation and is still there?
Old Jan 25, 2023 | 06:57 PM
  #36
pjdbm's Avatar
pjdbm
Thanks for your reply
Yes the AGM battery was the first thing I did when I got the car. Everything below was good as well as the PCM and all the wires to it. I pulled the cover off the pass wheel-well years ago to clean the udders and I inspected all the wiring at the time.
I got this pretty clean with CRC QD contact cleaner, I hit it twice more after this photo and even used a Q-tip to get everything spotless, I pulled each wire to make sure they were good but did not do a continuity check on each wire.
The only wire that I repaired was the orange wire you see loose in the photo, the wire had nothing to do with the relay or the fuse.
Old Jan 26, 2023 | 12:33 PM
  #37
C5 Diag's Avatar
C5 Diag
Can you just explain what was checked up to now...will have to study this circuit again to see what can be done to fix this !!
To 1999 Convertible hatch button does not work
Old Jan 26, 2023 | 12:54 PM
  #38
pjdbm's Avatar
pjdbm
Hi Rob,
The fuse 17 has voltage, the relay top right socket #86 has voltage
Old Jan 26, 2023 | 01:11 PM
  #39
C5 Diag's Avatar
C5 Diag
Hi Rob,
All relays should have 2 power sources...with a 12 volt test light do you see 2 ??...you said 86 which is the control side...87 is the power feed side...I don't remember if you swapped relays...the BCM grounds the control side ( see schematic) which closes the contact to allow power to the actuator...to see if the the control side is being grounded we can use the 12 volt test light.
Old Jan 26, 2023 | 01:36 PM
  #40
pjdbm's Avatar
pjdbm
I just confirmed with a test light that I have voltage at both top sockets 86 & 87 of relay.
