Steps/Process to replace pads and rotors
manuals? if you are gonna buy any buy the 3 volume set from one of the vendors...don't waste your money on Haynes/Chiltons....hell for that matter I will be selling my set for a 99 now that I have taken my entire car apart
You can YOU TUBE "SEARCH" this:
c5 corvette brake pad replacement Look at all the stuff that pops up. YOU TUBE is a little more hands on friendly.
The REAR rotors are a PAIN because of the E-brake!
Some STUFF that I have learned over the years:
The rotors are wheel/side specific!
The caliper actually SLIDES in and out on grease pins. The grease pins are protected by a rubber boot. You need to make SURE that the pins are free to move! The greased pins MUST be able to freely slide!
YOU need to replace or should replace the old grease with new grease. The grease MUST be synthetic grease made specifically for that purpose!!!
Open the caliper bleeder fitting before you depress the piston back into the caliper. That way you are not forcing NASTY dirty contaminated fluid back into your system. It squirts out of the bleeder vs back into your system..
Suck as much old fluid out of the master cylinder that you can. I actually take my reservoir off the master cylinder and flush it out with brake parts cleaner before I start and then refill it with good fresh DOT4.
MAKE SURE THAT THE MASTER CYLINDER DOES NOT GO DRY WHEN BLEEDING!!!
I use a very light coat of anti seize compound between the brake pad mounting tabs, the stainless steel anti rattle clips and the caliper slots.
BC
Golden advice. Bought my car and couldn't believe how much the brakes squealed, after some research I learned many people considered it "normal" for a metallic type pad. Not willing to accept that answer, I took the pads off and applied small dabs of anti-seize on the "ears" of the pads and anti rattle clips. Squeal gone entirely, took me about 20 minutes.
