Diff mount
Old Nov 24, 2017 | 05:54 AM
Rob 02's Avatar
Rob 02
When you hook up you will have wheel hop.
Wheel hop is about the only thing that will break the drive-line.
Old Nov 24, 2017 | 12:19 PM
mre1974's Avatar
mre1974
Hmmm....the more I look at this and think about it all I need is a few hockey pucks and a piece of aluminum or metal bar stock. I already have a drill press and metal bits.... IF this works and eliminates wheel hop and does't cause anything else to break it's a bargain price win in my book.
Old Nov 24, 2017 | 01:25 PM
99blkfrc99's Avatar
99blkfrc99
I was figuring the stock mount is directly in the middle. Not much to stop wheel hop other than a solid mount. Which I think would break things. So by putting 2 points of contact in hopefully supports it better and more even. It's basically like the Hoosier mount but doesn't have the bushing in the middle which I think could still contribute to the problem because it's a pivot point.
Old Nov 24, 2017 | 04:45 PM
mre1974's Avatar
mre1974
Yep, makes sense to me as well as is far less costly than the PFADT or Hoosier piece.
Old Nov 24, 2017 | 04:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GM designed the mounting system to reduce or eliminate NOISE/VIBRATION//HARSHNESS. Anything that you do the the mounts, will increase NVH. Some people HATE any NVH! Some could care less.
Just be aware that you will have a WHOLE new world of noises,& vibrations to deal with.
I agree that what ever you do to the rear mount, you should do to the front. On a scale of 1-10, a stock mount would probably be a 4-5. That hockey puck would be a 7-8 and a solid metal mount would be a 10..
Bill
Old Nov 24, 2017 | 05:00 PM
Smoken1's Avatar
Smoken1
I thought AFE Power got all the Pfadt stuff
Old May 30, 2018 | 04:16 PM
TastyBacon's Avatar
TastyBacon
Hey 99blkfrc99, how'd this thing work out for you?
Old May 30, 2018 | 04:40 PM
lionelhutz's Avatar
lionelhutz
I missed this before but it's a cool DIY solution.
The change I would make is I'd put a bigger clearance hole in the bar and then put a puck or rubber washer on the top as well. Use a big fender type washer on the bolt. That way, it can move in both directions, and can be tuned by using different thicknesses or durometers of puck.
Old May 30, 2018 | 04:52 PM
TastyBacon's Avatar
TastyBacon
Right, rubber on both sides of something, either the bar or the cradle, would be best for isolation. I would eliminate the rubber washers under the diff case and hard-bolt it to the bar, too. Nyloc nuts on the long bolts through the pucks should keep it together.
Old May 30, 2018 | 07:23 PM
lionelhutz's Avatar
lionelhutz
I didn't even notice those washers under the diff case. Yes, get rid of them too.
Old May 31, 2018 | 11:57 AM
99blkfrc99's Avatar
99blkfrc99
Well, I actually sold that car in February. Since have gotten another one. Going to be building the diff and clutch soon tho. So I will probably make another one. I did drive it a couple times before I sold it and it felt like the drivetrain was way more solid. I little vibration which was to be expected, but nothing harsh. Never got to launch it at the track.
Old Apr 30, 2020 | 11:23 AM
voda1's Avatar
voda1
This mount functionally replicates the c6 mounting system.
