C5 Powertrain Removal
Old Dec 16, 2017 | 07:37 PM
Aaron Drake Steadman's Avatar
Default C5 Powertrain Removal
Alright so im going to be removing the powertrain from my 2000 c5 6 speed coupe here soon and im looking to get some advice/tips. Im a shade tree mechanic, ive pulled motors and several transmissions in the past, but this will be my first time doing it with a vette. The plan right now is to use 2x12x12 under each of the four jack stands to raise it high enough to pull everything out. I plan to drop the rear cradle/torque tube first, and then the motor so i dont have to worry about trying to get the motor off of the shaft on the tt. If this is not the best way let me know! Not to be an *** but if you havent done this job before im not really looking for your input.
Old Dec 17, 2017 | 02:02 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I know my mechanic does it on a lift with a couple trans jacks....its like only 8 bolts to drop the whole thing......I dunno about doing it yourself though
there are a few here who have done it so hopefully they chime in
Old Dec 17, 2017 | 03:07 AM
I will be doing the same, minus the lift lol i have 4 pretty tall harbor freight jackstands, a trans jack and a low profile jack, and several smaller jackstands for precaution. Ive done several clutches on jackstands and never had any major issues. Im pretty confident i can do it, i just want to go about it the easiest way possible.
Old Dec 17, 2017 | 05:19 PM
am3gross's Avatar
am3gross
when you do it take lots of pictures/videos. i have not seen many online at all. good luck and hopefully you get accomplished what you are shooting for. Merry Christmas!
Mike
Old Dec 17, 2017 | 05:42 PM
DetroitPlac's Avatar
DetroitPlac
If doing it on the ground, I'd start with jackstands under the crossmembers. Then disconnect the 4 crossmember bolts, drop the exhaust, remove the tunnel plate, then start disconnecting all the little stuff...parking brake cables, all wires you can see, coolant hoses (probably best to just pull the radiator to give you more room).
Once you've got everything disconnected, start jacking the body up on one side. Raise it a bit, put jack stands under, and move to the other side. Keep going side to side until you have it raised as much as you want.
I did it on a lift, but I could see it being possible on the ground. It's WAY easier to work on the powertrain with it in tact separated from the body.
Old Dec 17, 2017 | 06:23 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I would drop the rear subframe supporting the trans/diff etc with a transmission jack. I then unbolt the torque tube from the bellhousing to drop the torque tube, trans, and diff. You can then pull the motor from the top.
If you are putting the car back on the road, keep and eye on the torque tube and shifter box clearing the lines in the trans tunnel. Go slow and keep an eye out for any snags on wires, lines etc.
Guys have dropped both subframes, engine to diff at once, I would only do it on a left. We use large stands in the 4 puck locations and another under the engine. I highly recommend doing it with another person especially the first time.
Old Dec 17, 2017 | 08:12 PM
Rob 02's Avatar
Rob 02
I did everything in stages as needed. You get the car up high enough to remove the exhaust and cover plate. Then lower the drive-line. Then raise the body more. I used small jack-stands for the drive-line and larger ones for the body.
Old Dec 17, 2017 | 09:04 PM
Definitely appreciate all the advice. It makes me feel a lot better about it seeing it done! Lol i will take as many pictures as i can. Im going to take my time with it to ensure everything is done properly but i will update as often as possible. Thanks for all the help guys 🤙🏽
Old Dec 17, 2017 | 09:07 PM
[QUOTE=Rob 02;1596199625]I did everything in stages as needed. You get the car up high enough to remove the exhaust and cover plate. Then lower the drive-line. Then raise the body more. I used small jack-stands for the drive-line and larger ones for the body.
I believe this is the approach im going to take. Did you also use a trans jack to drop the front cradle?Edit: nvm i now see that you did. 👍🏼
Old Dec 17, 2017 | 09:12 PM
Rob 02's Avatar
Rob 02
The engine wiring harness is a little tedious but fairly straight forward.
If it is a higher mileage Vette I would definitely replace torque tube bearings and couplings.
Old Dec 17, 2017 | 09:14 PM
Rob 02's Avatar
Rob 02
To get the front bumper that high I put wood under the front jack stands and lowered the rear a few notches.
Old Dec 17, 2017 | 09:23 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Old Dec 17, 2017 | 09:39 PM
I actually bought a z06 tt with low miles recentley and im getting the upgraded RPM poly couplers for it. Have plans for a full build! Mild build anyway, looking for 450-500 whp
Old Dec 18, 2017 | 01:56 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Look on youtube, they have lots of how too videos
mike v
Old Dec 23, 2017 | 03:30 PM
Made some progress on the vette. Wont start on the motor removal for a couple more weeks as im waiting for parts in the mail but so far so good. As you can see it definetley needs some attention.
Old Dec 23, 2017 | 05:22 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Old Dec 23, 2017 | 07:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DO NOT USE IMPACT TOOLS on the cradel bolts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!
To C5 Powertrain Removal
Old Dec 23, 2017 | 08:59 PM
Only used it for the tunnel cover lol 👍🏼👍🏼
Old Dec 27, 2017 | 07:33 PM
Rob 02's Avatar
Rob 02
It looks like you have plenty of garage space.
Old Dec 27, 2017 | 09:00 PM
3 bays thankfully i do have plenty of space 🤪
