Bumpy ride
Old Dec 21, 2017 | 10:44 AM
alucero258's Avatar
alucero258
Default Bumpy ride
Hello,
I am looking to see if anyone has ever had a similar problem or advice.
2000 Corvette, auto, 100k miles, headers, intake, was lowered for several years, year ago raised to stock height.
The problem.
Driving 60 MPH traffic stops I have to slam on the brakes, brakes lock up and skid for 30 feet. Ever since that incident the car feels and sounds like I am running over bumps in the road.
Thank you for any advice.
Old Dec 21, 2017 | 10:48 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Warped rotors? Is it only bumpy when applying brakes, or all the time?
Old Dec 21, 2017 | 10:51 AM
Quickshift_C5's Avatar
Quickshift_C5
Good question. If it's only when applying brakes, the rotors are probably not warped, but there is a good chance of a high spot on the rotor from the brake pads getting hot after the panic stop and resting on the rotor surface. Especially if you're using generic off the shelf cheap pads from a local supplier. A good brake bed-in procedure will likely fix that.
Unless your ABS isn't working and you flat spotted a tire, I don't see it being anything else if it's related to this 60mph stop incident.
Old Dec 21, 2017 | 11:51 AM
alucero258's Avatar
alucero258
It is happening all the time and not just during braking.
The ABS light is on, so your suggestion that the tires have a flat spot makes sense.
Thank you for your responses.
Old Dec 21, 2017 | 11:59 AM
Quickshift_C5
You should be able to pull up the DIC codes and see what's going on with the ABS. Check here -> http://www.stengel.net/diccodes.htm
Good luck!
Old Dec 21, 2017 | 02:06 PM
Moved to C5 Tech.
Old Dec 22, 2017 | 12:21 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your braking system is HOSED!!! You need to FIRST, read and post all of the DTCs using the onboard diagnostic routine in the DIC.
You MUST read the DTCs after you have take the car for a short drive and NOT turning the ignition OFF.
You most likely have a TON of old DTCs so, I would clear ALL of them, take the car for a drive and then read the DTCs. Report ALL of what comes back
If you have warning messages in the DIC, press reset till they go away.
Cant wait to see what DTCs you have...
Bill
Old Dec 22, 2017 | 06:07 AM
runner140*'s Avatar
runner140*
OR, a broken shock. Get the car off the ground, high enough to check each wheel and suspension. Ball joints, tie rods out of adjustment. It could be one of many things. You have to get under it and take a look.
To Bumpy ride
