Trunk lid does not open
Old Mar 28, 2018 | 09:03 PM
Ron Fairs's Avatar
Ron Fairs
Default Trunk lid does not open
I've owned a 2001 conv. since new. During the last couple of years the trunk lid has become increasingly harder to open because there is not enough room to put your fingers in to lift the lid. Would new trunk lid struts help?
Old Mar 28, 2018 | 09:11 PM
glbeauchamp's Avatar
glbeauchamp
Yes. Or this: https://www.corvettemods.com/C5-C6-C...SABEgKj1fD_BwE
Or look at this thread: https://www.corvetteforum.com/forums...er-spring.html
Old Mar 28, 2018 | 09:14 PM
sloopdawg's Avatar
sloopdawg
I got a '01 Vert as well (did the same thing)
Best 15 bucks you'll ever spend
Old Mar 29, 2018 | 09:01 PM
C5 Kirkland's Avatar
C5 Kirkland
New trunk struts would help if you have to hold it open after you have dug your nails in to open it in the first place. If it stays open, order the spring from corvettemods.com.
Old Mar 30, 2018 | 11:39 AM
robmiz's Avatar
robmiz
On the trunk lid there are two rubber stops. Unscrew them to increase length, this will raise the lid when unlocking.
Old May 18, 2018 | 06:22 PM
Ceedub53's Avatar
Ceedub53
I had the same issue on my 99' Vert. That spring really helped because it pushes the trunk lid up enough to get your fingers under it and open.
Old May 18, 2018 | 07:56 PM
Fast one's Avatar
Fast one
There's a spring on the latch that is supposed to be strong enough to lift the trunk lid about an inch when the solenoid is actuated because the gas springs don't do much at the closed angle.
Here's the spring and latch with the cover removed and the trunk open:
Check the spring to make sure it isn't broken or too weak to be in the position shown. The old original grease in the latch becomes dirty and dries up causing the parts to bind. Try cleaning the latch assembly with solvent and apply new grease such as Mobil 1 to the moving parts. It's a good idea to do the same with the parking brake handle assembly and hood latches since the grease in those is almost two decades old as well.
Old May 18, 2018 | 09:28 PM
3sACROWD's Avatar
3sACROWD
Go to the local hardware store and buy two springs that are 1.5" long. Cut the ends off so you can feed the spring onto the shaft of the shock. The springs open the deck lid and won't rattle when closed because the springs are compressed. Cheap and completely out of the way. Cost about $5.00.
To Trunk lid does not open
