Fixed my Passenger Window/Mirror/ Lock problem
I have a 2000 FRC; Fixed Roof Coupe.
My passenger window stopped operating suddenly. Wouldn't go up or down, could not adjust passenger mirror or operate door locks. The left door worked OK, just the right door had problems.
I performed a check for any codes via the DIC; and found that I had "Loss of Com" with the Right Door Controller. No codes there, apparently it can't report what's wrong if it can't communicate!
I could not find a troubleshooting guide for "Loss of Com", if I had a code there are guides...
I looked at the Corvette Forum for hints and watched a couple of You Tube videos to figure out how to remove the door panel.
I tried whacking and slamming the door, but it still wouldn't work.
Checked fuses 30 and 31 and they were fine.
Luckily I have Factory Manuals for a 2003 Corvette and was able to find what kind of voltages should be at various pins on the connectors to the Right Door Control Module; DCM. Not all the signals, but at least the 12VDC, Grounds, etc.
I spent two days before I found the problem and I looked at this connection several times and can't believe it was this. To make a long story short it was a bad ground connection at the green connector on the DCM.
There was no corrosion or burn marks, it was just not enough spring tension inside the connector to make good contact with the metal pin on the DCM.
I had noticed that when everything was connected and I measured at several various ground connections on the DCM I was getting about 6 VDC instead of Zero. I thought it might be a bad ground connection at G202, which is at the floor level at the bottom of the A-Pillar, but could find nothing wrong there. Putting one lead of my Volt Meter at this ground location (G202) and then measuring with the other lead at connector C-3, pin F, I measured about 6 VDC. Measuring at several other pins and connectors; C-2, pin C, C-4, pin 9, all measured about 6VDC, instead of zero. These are all ground connection. All of these are easy to check at the door control module, but you have to find a known good ground. You could always use the negative terminal of the battery.
All these connector and pin locations have Black wires on them, so you can just back stab the connector with a paper clip and check the voltage to ground. It should be zero. If not, it's not a good ground.
I took my loose fitting pin and placed a small screwdriver into the back side of the connector to bend the little "Leaf Spring" for more tension.
Hopefully this can help someone in the future and save some time troubleshooting. Just look for zero voltage on the ground wires...
I have a few pictures that might help, but don't know how to post them. If someone is willing to post them for me, please let me know your e-mail address and I can send them to you.
Thanks for listening.
Mike
1. At your dialog box, click on the "Insert Image" icon. (it looks like a picture of a mountain).
(see first picture)
2. At the next page, click on the green bar that says "Browse your Device" and choose your photos. Click "Open" when you find them.
(see second picture)
3.Click "Insert" in the right upper corner to upload.
The female pins of the connector on that wire harness get deformed, causing bad contacts and isolating the door control module. In addition to that, this could also cause a loss of communication/corruption in the Serial Data Bus affecting all modules linked by it.
Check the connectors in both doors for deformed pins. If bad pins are found you would need to repair the connector, fixing the female pins so they have a positive grip, or replace it. If you want to replace the connector take a look at this post for some ideas.
