C5 bogs down when accelerating
Old Jul 6, 2018 | 08:56 AM
SG Lou's Avatar
SG Lou
It probably wouldn't hurt to clean the Throttle Body as well. I had a hesitation / bogging issue upon acceleration and when i removed the air bridge off of the TB i can see the area around the blade and the blade itself covered in carbon. I removed, cleaned and reinstalled the TB. No more hesitation !
Old Jul 6, 2018 | 09:19 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Good Show !!....speaking of Throttle Bodies a really dirty one can set a P0106 DTC..."MAP Sensor circuit Range/Performance"...MAP sensor looks at RPM and Throttle Position....if TP is skewed because of Throttle Plate not fully closed...BAM !!....P0106 !! ...I see you're in NJ also...are you a member of the Central Jersey Corvette Club ?? ...I'm thinking of joining...might show up at the July Club meeting !!
Old Jul 6, 2018 | 09:56 AM
SG Lou's Avatar
SG Lou
Originally Posted by rwobs777
Good Show !!....speaking of Throttle Bodies a really dirty one can set a P0106 DTC..."MAP Sensor circuit Range/Performance"...MAP sensor looks at RPM and Throttle Position....if TP is skewed because of Throttle Plate not fully caused...BAM !!....P0106 !! ...I see you're in NJ also...are you a member of the Central Jersey Corvette Club ?? ...I'm thinking of joining...might show up at the July Club meeting !!
Hi Neighbor, No I'm not a member of that club but...there is a bunch of us that get together for shows and cruise nights in the area but mainly in Howell and Jackson.
If you happen to be on Facebook you can check us out and join in....https://www.facebook.com/groups/njvetteowners/
Old Jul 6, 2018 | 10:36 AM
C5 Diag's Avatar
C5 Diag
GREAT !!!.,...Thanks !!
Old Jul 6, 2018 | 12:47 PM
Bill Dearborn's Avatar
Bill Dearborn
OP: There is no need to purchase a code reader. Your car has an On Board Diagnostic system that is better than any cheap code reader you can purchase. It can read all of the codes on the car not just the powertrain codes which are only 55% of the total number of codes that can be generated by some sort of failure.
Bill
Old Jul 7, 2018 | 09:12 AM
SG Lou's Avatar
SG Lou
[QUOTE=rwobs777;1597545297]Good Show !!....speaking of Throttle Bodies a really dirty one can set a P0106 DTC..."MAP Sensor circuit Range/Performance"...MAP sensor looks at RPM and Throttle Position....if TP is skewed because of Throttle Plate not fully closed...BAM !!....P0106 !! ...I see you're in NJ also...are you a member of the Central Jersey Corvette Club ?? ...I'm thinking of joining...might show up at the July Club
Old Aug 16, 2018 | 06:00 PM
hornet7's Avatar
hornet7
Default Fuel Pressure
Originally Posted by billschroeder5842
Check your fuel pressure at the Schrader valve. You may have a weakening fuel pump or your fuel filter may need to che changed.
Congrats on the new Vette!
What should the fuel pressure be?
Old Aug 17, 2018 | 01:13 AM
My Vette Life's Avatar
My Vette Life
Dont think anyone mentioned the plugs as a culprit.
