Voltage Fluctuation on DIC - Alternator?
For context, I am in sunny inland Northern California, where rust is never heard of, and I've never had a non-start (aside from when I rat chewed up some cluster wires under the computer below the battery several years ago, but that's a whole 'nother story), so I don't think this is a connection issue, Logic tells me that this is an indication of the regulator inside the alternator starting to go out, but I have been know to be wrong.
A brand-new GM factory alternator is over $500, so I would like to narrow this down as much as possible before plunking down the money, so thoughts, and suggestions would be most welcome, as would tips on to how I might test the alternator vs. battery with a multi-meter.
https://www.corvetteforum.com/forums...ch-repair.html
I wonder if my 2000 Suburban battery would fit in the Vette. Then I would be able to swap batteries for good measure and see what the DIC reads then. What do you guys think?
If the contacts inside the ignition switch are burnt, corroded, dirty, the voltage will be compromised and something lower than actual battery voltage or alternator output.
The ONLY way to see what actual battery voltage and or charging voltages are is to use a DC Volt meter on the battery terminals when the engine is running. You can also compare the actual battery voltage to the alternator output voltage by reading the BATT TERMINAL on back of the alternator to chassis ground. You can compare those readings to what you see inside the car on the meters.
ALTERNATOR. If you have significant mileage on the car, the alternator rotor SLIP RINGS are probably very dirty. That can and will have a direct effect on the alternator charging voltage. Its VERY SIMPLE to clean those slip rings. There's an EXCELLENT You Tube video on that exact topic.
Just You Tube search "VALEO ALTERNATOR REPAIR" The videos by (WESTRONICSLRL ) are excellent and all you need to self repair your alternator.
EASY AS PIE!
Bill
I was experiencing wild voltage fluctuations that got worse and worse. The bad connection made the computer think the charging voltage was too low, causing the alternator to put out 15 volts and higher. This high voltage cooked the battery - it died shortly after a couple of high voltage events. I replaced the connector with one out of my junk box. Took 30 minutes. The alternator voltage has been perfect ever since.
EASY AS PIE!
Bill
As I mentioned, Autozone diagnosed as a bad battery. They also said my voltage dropped to below 10 volts when I start the car. Is that normal? I put a new battery in, and now I only see it drop into the 11 volt range.
BTW, not to hijack my own thread or anything, but on your ignition switch write-up you included instructions to r&r the IPC. I've never tried to access it, but I thought only the center console and knee booster needed removal to get to the switch. Am I wrong? If I have more questions on that topic, I will post them there, where they belong.
I haven't looked, but is that connector accessible from the top or bottom? Is it an easy reach, either way? And, what color is the wire to that connector?
As Pjensen pointed out, the alternator VOLTAGE FEED BACK signal comes from a wire (fused) that is attached to the starter solenoid. The alternator BATT Terminal outputs to the battery. It ALSO goes to the main terminal on the starter solenoid. All that being said, the wires on the starter solenoid MUST be clean and tight to have the proper connection and allow the alternator to work properly. With out that feed back wire making proper contact, the alternator output can and will be all over the place.
IF your battery doesn't have the proper reserve capacity and cold cranking amperage,YES, I have seen them drop very low when the starter draws lots of amps to turn the engine. Battery voltage is INVERSLY proportional to current draw. I have seen a bad battery drop as low as 8 volts under starting current draw and still be able to crank the engine. The C5 electrical modules DO NOT LIKE LOW VOLTAGE.
Its normal to see 11 VDC on initial starter engagement. As the engine spins the engine and draws less current, that voltage reading should increase until the engine runs and the alternator starts charging.
NOTE. The alternator will not always output it's full charge voltage. It can and will adjust the output to meet the demands of the electrical system and needs of the battery. 13.5 to 14.7 is the normal range that you should see (at the battery terminals)
REMEMBER,,,,, The volt meters in the cabin DO NOT represent actual battery charge voltage!
Based on what you said about how the alternator works under start and run, it sounds like my DIC is reading correctly, but I can compare to direct readings on the battery and Alternator, to verify.
Also, maybe i should check the starter wires just to be sure they are sound. Is that what you're saying? How hard is it to get to them?
It kept getting worse, sometimes jumping up to 16 volts. I turned on the head lights to load down the voltage to 14.5. Sometimes the display would say HIGH VOLTAGE and shut down the entire dash. Scared the crap out me. I was worried that it would destroy all the electronics and computers if it didn't get fixed immediately.
Got home and started reading all of Bill C. posts on the electrical system. Final came across one thread that explained the alternator/starter wiring. Ten minutes later, I was under the car and found the oxidized connector on the starter.
Ever since, the alternator voltage shows to be 14.1 to 14.3. When I have the a/c and lights on, it might get down to 13.9 or so.
By the way, thanks Bill C for the incredibly helpful posts.
EASY AS PIE!
Bill
Lots of poor connections get "fixed" by constantly replacing the battery since it's become such a forum mantra to keep a new battery in the car at all times.
The alternator on a C5 does NOT vary it's output voltage based on system loads or driving conditions or anything like that. The alternators on most of the newer GM vehicles do, but the C5 PCM does not have any control over the output voltage of the C5 alternator.
There is a wire from terminal D of the alternator connector that runs to the starter solenoid. THIS wire is the output voltage feedback used by the regulator inside the alternator. A bad connection on this wire at the solenoid could provide a lower voltage to the regulator which would cause it to in turn increase the alternators output voltage level trying to compensate.
The PCM has NO control over the output voltage of the alternator. The F or field wire is only so the PCM can monitor the PWM level of the regulator. Stop spreading this false information.
Weirdly I knew about the voltage regulator on the back of the C5 alternator (and that voltage sensing wire that goes down to the starter). Late night posting mess up. Sorry.
