Adding 100rwhp to c5
Unlike me...
POWER:
Ported higher compression Patriot Performance heads 202 intake valves, Ti retainers
42 lb/hr injectors
Home Ported Fast 90 intake,
Ported 90mm TB
Stainless Works Ceramic Coated 2/3/4 headers.
Full 3" Stainless works exhaust
VARARAM Cold Air Intake
243, 610 lift 114+4 cam
180 deg thermostat.
PCM tuned
RELIABILITY:
LS2 Timing chain with LS1/6 timing chain dampener
Caddy Racing Lifters
Hardened push rods
Gold dual springs
New Lifter buckets
ARP Head Studs
ARP Dampener bolt
Power Bond/Dayco 25% dampener
EMISSIONS. CT DOES NOT require tail pipe emissions. They just connect the system to the OBD2 port and if you do not have any emissions related DTCs, you PASS. The car still needs to be in the bay and on the rollers so the state required monitor CAMERA can record the guy actually emissions testing your car. Some cars that don't pass can elect to have the car run on the emissions dyno.
DRIVETRAIN MODS:
T60/60 TRANSZILLA MN12 Conversion
Differential C6 ZO6 hardened output shafts, C6 ZO6 clutches, Hardened spider gear cross shaft
ECS Trans brace
Torque tube disassembled and check for viable couplers and bearings
PFADT Differential mount
C6 ZO6 shocks
3/8" aluminum tunnel plate
Spec Dual Disk Clutch with all new: Pilot bearing slave, throw out brg and remote bleeder Properly measured for correct shim install (not needed in my install)
Pressure plate properly off set balanced to eliminate any possibility of any drivetrain vibrations issues.
TIRES/Rims CCW 505a 19X11.5 wide rims, TIRES= Toyo Proxis T1R, rear 315/25/19, front 275/30/19
Tick Master Cylinder
I'm sure I left something out.
Bill
Yes it was a LOT of expensive parts BUT, I did ALL of the work my self (except the T60/60 Conversion) and saved on the labor cost. I shopped around for the best deal on parts that I could find at the time. I know it was all done correctly.
I didn't even include the plugs, wires, coolant, brakes, other fluids, gaskets, new oil pump, seals ect in the cost.....
My wife and I both work, have good steady jobs, kids are grown and on their own "sort of" and we save cash for the thing we want (don't necessarily have to have). So,, this was a long term goal project and I achieved that goal of 450 RWHP or better. .
It feels good to achieve a goal. If I need more power at this point, I would add some Nitrous. Maybe one day.
We also have a 11 Grand Sport Vert. Its my Wife's. Completely stock.
IF,, I ever get a chance to mod it, it will be Supercharged with reliability engine/drivetrain mods. Nothing extreme!
Bill
You can make the C6 Z06 run with the stock C7 Z06 (non Z07) but again you would be lucky to be money ahead.
Bill
235/243 .630/.610 111 lsa. It’s whu I went with the aftermarket heads for the extra ptv and I had a bad lifter and I’d be darned to pills the stock 853 heads to bolt those turds back on lol and yea I do all my work myself too. That way you know it’s done right. My buddies got picture of me sitting down inside the engine bay when I couldn’t get that dang oil pickup tube bolt in lmao
If I were to go back and do it again I’d look into forced induction as well. I tried to reply but it didn’t go through
plus with your smog stipulation it may be easier to pass smog tests? We don’t have that where I am. Hell you roll in and they check your lights and slap your sticker on
Even IF and WHEN you get that magic 450 RWHP goal,,,,,,,, YOU HAVE A WHOLE LOT MORE MONEY that you need to invest to make it reliable!!
TRACTION! NON EXISTANT! = On the stock size tires and normal driving rubber it will be difficult to put this power to the ground reliably!!
WHEEL HOP/DRIVE TRAIN SHAKE! = If you don't address "engine mounts" "differential mount" "shocks" & "tires" your will have a very difficult time launching, gaining traction and most likely experience wheel hop! Wheel hop can equate to broken differential and or transmission. IF,, you put sticky tires on the rear, and launch hard and gain any sort of decent traction, you will most likely pop the differential output shafts.
Your torque tube rubber couplers will most likely NOT survive the transformation. You most likely have the 10mm couplers and the rubber couplers are most likely dry rotted and ready to POP! 97-2000 C5s have the 10mm couplers.
Clutch: IS NOT GOING TO BE HAPPY with anything over 420 RWHP! You will most likely get the PEDDLE STUCH TO THE FLOOR issues.
Just some things that I've seen that give people problems when they make engine mods.
I have an 02 ZO6 that I've modded and have reached that goal. TRUST ME,,, IF,,,,,,,,,,,,,,,,,,,,,,,,,,,, I had it to do ALL OVER AGAIN, I would have gone the Forced Induction Route!!!!!!! Not that I don't like my Heads, Cam, Fast 90/90, Header engine; but the FI engine is MUCH MORE drivable and reliable.
BC
You dont need special lifters, oil pumps, etc. If anyone can squeze the most out of an LS1 and pass smog its him. His LS1 ran awfully strong, took a good ear to tell it wasnt stock.
I dont think you have to deal with the sniffer just the visual/plug in.
What area are you in?
Or you could skip that stuff and go straight to a CARB-approved supercharger, and have more power than most (all?) naturally aspirated C5 Z06s.
Are torque tube couplers going to be a problem at 450whp for someone who doesn't drag race?
Upgraded air intake and exhaust (headers?), cam and stock everything else?
You will need to upgrade your:
Headers, heads, intake, TB, and a mail-in tune will get you about 75-85RWHP. If you want to get up to the magic 100 mark, port what you can, larger injectors, and dyno tune.
also I seen people suggest roller rockers and things. Please be careful with these as most roller rockers add a lot of nose weight. Which is where it counts in valvetrain stability at high rpm. Texas speed has some super nice ones that are almost as light as oem with upgraded trunnions. I personally have the tsp trunion upgraded stock style and I’m on .630 lift and have good pad contact. However my valve angle is slightly different due to aftermarket heads
