Smoke from exhaust
Old Sep 10, 2018 | 07:21 PM
  #61
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Originally Posted by Georgies
When u say hold rpm at 3k... hold it there for like 30 seconds or a few minutes??
ill look into the blue driver.. thank you!
A few minutes...if seals we will try to burn off some of that oil !!...With the Blue Driver you download the app whether you have iPhone or Android.
Old Sep 10, 2018 | 07:39 PM
  #62
Georgies's Avatar
Georgies
Id like to add my O2 sensors currently on the car are the originals from back in 2003.
i only have 2 of them since i have the ARH catless longtubes/x pipe.
i was able to fit the stock ones without the extensions. It just fit, so wire is bent over at the sensor connection. Not really hard but could it be a concern?
Old Sep 10, 2018 | 07:50 PM
  #63
C5 Diag's Avatar
C5 Diag
Not good to have to much “tension” on the wiring...If the O2’s were “stuck” lean or rich it would throw a DTC...or an issue with the heating circuit too...it would be interesting what your sensors are doing...my ‘01 has 55,000 miles and my O2’s are starting to look “lazy”...I’m just to “lazy” to change them...LOL !!
Old Sep 10, 2018 | 07:56 PM
  #64
Georgies's Avatar
Georgies
So if its the seals, after holding at 3000 rpm for a few mins, the smoke should stop for a while??
Am I undersranding this correctly??
Old Sep 10, 2018 | 08:00 PM
  #65
C5 Diag's Avatar
C5 Diag
Yes, if seals it should stop permanently after a few minutes...engine vacuum is low so oil would not be pulled into the cylinders and burned !!
Old Sep 10, 2018 | 08:10 PM
  #66
Georgies's Avatar
Georgies
Hold on im not getting this. It should stop while holding it there, or is this some sort of magic cure for leaky valve stem seals lol
Old Sep 10, 2018 | 08:29 PM
  #67
C5 Diag's Avatar
C5 Diag
No magic !!...as the piston goes down on the intake stroke (vacuum) if the valve seal were bad the vacuum draws the oil from the cylinder head into the combustion chamber past the seals !
Old Sep 11, 2018 | 09:11 AM
  #68
Georgies's Avatar
Georgies
Ok thanks!
i will try once it stops raining.
ive found this thread interesting about valve seals..
https://ls1tech.com/forums/generatio...-unseated.html
Old Sep 11, 2018 | 04:47 PM
  #69
Georgies's Avatar
Georgies
Ok i tried holding the rpm at 3000k for 3 mins. Some smoke was coming out. Once i let go of the gas it started smoking just like before.
what does this mean?
Old Sep 11, 2018 | 04:57 PM
  #70
Georgies's Avatar
Georgies
Im starting to take off the pass valve cover just to take a look. Also wanna clean the coil ends as I put way too much dielectric grease in them. What should I use to clean? Brake cleaner??
Old Sep 11, 2018 | 05:12 PM
  #71
C5 Diag's Avatar
C5 Diag
Ya know what ??...pull the PCV off and see if there is a lot of fresh oil inside the hose...the PCV "rattle test" is NOT a good test either !!!...a manometer would be the tool to use to verify...I don't even have one...LOL !!!...you might have excess crankcase pressure causing oil to blow by your valve guides....do that before you start ripping stuff apart !!...I'm thinking to myself...KISS...keep it simple stupid !!
Old Sep 11, 2018 | 06:05 PM
  #72
Georgies's Avatar
Georgies
Ok i pulled it off... and i dont remeber how it goes back on damn! I was called away for some help. Damn! My car is a 2003.
there is some oil inside, i used a q-tip to see how much. Doesnt seem like much but i dont know anything about this..
heres how i put it back. The air flows towards the intake manifold. If i blow the other way, a little air passes then it locks.
Old Sep 11, 2018 | 07:03 PM
  #73
Georgies's Avatar
Georgies
Opened up pass valve cover and cleaned the grease from the coil packs while i was at it.
its hard to see tha valve stem seals with dual valve springs. However, i did see all valve stem seal springs intact. Some looked to have a kink here and there but i remember some looked that way when i pushed them on. Also, no debris inside the valve train area..
Old Sep 11, 2018 | 08:47 PM
  #74
redzg's Avatar
redzg
Sweet looking cylinder heads! If I read an earlier post correctly, you had some smoke while holding the throttle at a fixed off-idle RPM, then the smoke increased when you released the throttle to idle -- yes? That, to me, sounds entirely like valve stem, either seals or guides. You are going to feel so good when you measure compression or leak down and know for sure your rings are O.K.
Old Sep 11, 2018 | 09:06 PM
  #75
C5 Diag's Avatar
C5 Diag
Brake Kleen is fine !!
Old Sep 11, 2018 | 09:45 PM
  #76
Georgies's Avatar
Georgies
Thanks man! And I hope you right. Id be very content if its valve stem seals! If you take a look at post #68 in this thread, I posted a link to a thread that talks about valve stem seals lifting/not sealing Its pretty interesting and Bryan Tooley even chimed in..
Old Sep 12, 2018 | 10:58 AM
  #77
Georgies's Avatar
Georgies
To Smoke from exhaust
Old Sep 12, 2018 | 01:22 PM
  #78
C5 Diag's Avatar
C5 Diag
Dude !!...NOOOOOOO...not another problem ??...LOL !!...what's the current situation with the smoke ??... did you ever get the PCV hoses figured out ??...I had said the "rattle test" is not the best indicator of PCV valve operation but just remove it and see if it does rattle for the heck of it...I saw you now have your Bluedriver...COOL !!...how do you like it ??...I see the 135 and 155's are current...when did these pop up ??...what I do see is your bank 1 O2 is not switching properly...what is bank 2 sensor millivoltage doing ??...they should be switching a little better from what I see...they should be switching from at least 200-800 mV or so...your numbers ARE indicative of a bad O2 sensor heater circuit for that DTC...you could look for a blown fuse...you only have 2 but all 4 heaters circuits come off 1 fuse... maybe someone can chime in with the fuse location. I'd also check out that wiring since you had mentioned you had quite a bit of "tension" on the wiring...a resistance check of the O2 sensor heater would also work...I can't remember the resistance but maybe 3-10 ohms ??...maybe someone can chime in with the "book number" !!...your short term fuel trims look OK too !!
Old Sep 12, 2018 | 01:28 PM
  #79
Georgies's Avatar
Georgies
What are banks? Im not familiar yet with alot of terms. Im a good mechanic, not very good car mechanic lol
Old Sep 12, 2018 | 01:44 PM
  #80
C5 Diag's Avatar
C5 Diag
A place where you get money from...LOL !!...on a V8 bank 1 is where the #1 cylinder is located... ours its the drivers side 1,3,5,7...bank 2 is passenger side...2,4,6,8.
