car stalls
Old Oct 29, 2018 | 10:56 AM
gary harrel's Avatar
gary harrel
1st Gear
Default car stalls
1998 corvette I started car this morning put in reverse , car moved 2 feet and shut off. I started again put in forward , it moved 2 feet and shut off. I kept doing this a few minutes , then it worked ok.
Old Oct 29, 2018 | 11:38 AM
grantv's Avatar
grantv
Pull and post your codes. If you don't know how; Google C5 pull DIC codes.
2MPH fuel cut off sounds about right...
Old Oct 29, 2018 | 10:30 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
column lock message on the DIC ?????
Old Oct 30, 2018 | 03:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like the column lock is giving you issues. If you don't already have one, you should get the LMC-5 Column Lock Bypass and install it BEFORE you get stranded somewhere!!
If it is the column lock, you will for sure get the DTC.
Bill
To car stalls
