What the hell is that sound?
Old Apr 2, 2019 | 12:56 PM
Ghostwheel's Avatar
Ghostwheel
Default What the hell is that sound?
So this started relatively recently. I had the transmission replaced by a local shop using a member heres transmission that had 20k on it. I've put about 1k on it but I suspect it's an installation issue? It only happens when I push in the clutch pedal, and in every gear. If I sit in neutral I hear nothing.
You may have to turn it up pretty loud to hear. It's a lot more obvious when you're just sitting in the car. (Ignore the change oil message, I just changed the oil)
Old Apr 2, 2019 | 01:13 PM
69's Avatar
69
Cruise-In VI Veteran
With the clutch pedal depressed, Sounds like a clutch throw out bearing or pilot bearing...
Goose
Old Apr 2, 2019 | 02:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,, Them having disassembled it, Did they replace anything other than the transmission????? Did they just remove the Trans/Diff or did they drop the DIFF/TRANS & TT also???? If they dropped the TT, they could have very well damaged the pilot bearing. NOT GOOD!!
YEP, sounds just like a pilot brg or throw out bearing. If it were me, I would drop the trans inspection cover and get an eye ball on the throw-out bearing. You cant see the pilot but they do go bad and tht can cause TT input shaft damage.
Bill
Old Apr 2, 2019 | 04:20 PM
50thz06's Avatar
50thz06
I agree with possibility of throwout bearing or pilot. Might be able to isolate the sound to that area better if car was up on a rack, but it sure sounds like one or the other.
To What the hell is that sound?
