DIC Problem
Old Apr 22, 2019 | 02:48 PM
LittleRiverBK's Avatar
LittleRiverBK
Cruising
Default DIC Problem
On initial start-up the DIC lights up with the normal Chevrolet banner, then it goes blank... and stays blank. Have checked all the fuses and cleaned the grounding blocks, but found nothing amiss. All other features of the instrument panel work fine. Have others encountered this problem? What corrective steps can I take?
Old Apr 22, 2019 | 03:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you actually measured the DC Voltage on the IPC Fuse??? On top of every fuse are two test points. Measure each test point to chassis ground. You should have battery voltage on them with the ignition ON! See if it goes away when it goes blank! If it does, you most likely have a bad ignition switch.
Old Apr 23, 2019 | 10:00 PM
LittleRiverBK
Cruising
Thanks Bill, I understand the process you describe, and we have not tried that. Will let you know the results.
Old Apr 23, 2019 | 10:01 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
To DIC Problem
