Clutch problems
Old May 5, 2019 | 06:44 AM
C422's Avatar
C422
Default Clutch problems
I have a 97 C5 with a cam, CAI, bore, and tune. I have a pretty cheap aftermarket clutch that the previous owner had for the car. Onto the actual problem!
When my pedal is pushed in, I sometimes get a metal-on-metal squealing that sounds like it's coming from the clutch. When this happens, I can't change gears. I can pump at the clutch until I hear a loud "think" from the clutch area, and then she'll shift fine again for a while.
The squeal exists even in neutral.
My first thought is my TOB/slave, but when the pedal is in, the car doesn't try to creep or anything. The clutch is thereby disengaging.
Sometimes, with normal driving, I'll smell the clutch when I get somewhere.
The transmission was rebuilt about 4000 miles ago with new everything that wears (including the shafts).
If no one's got any better idea, I'm going to go to a McLeod down disk with new slave/TOB, new pilot bearing, and TT rebuild. This car's my daily, but not shifting isn't acceptable, especially in Atlanta.
Thanks,
Kyle
Old May 5, 2019 | 09:29 AM
mmartinez's Avatar
mmartinez
Smelling clutch is not a good sign, I would also install a speed bleeder on your slave cylinder to bleed the hydraulic system in the future.
Old May 5, 2019 | 10:35 PM
C422's Avatar
C422
New slave (obviously with TOB), new McLeod RST twin disk, refurb the TT, new pilot bearing, and a remote bleeder with a speed bleeder valve.
Well. Hopefully something there fixes it. I'll have her buttoned back up by Wednesday.
Old May 6, 2019 | 03:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CALL ME!! I have a load of lessons learned for you. Hopefully its not too late the help you.
Bill PM SENT!
To Clutch problems
