Troubleshoot hot-start issues?
Old May 20, 2019 | 04:17 PM
Jackie N's Avatar
Jackie N
Default Troubleshoot hot-start issues?
Hey all, my 01 Z06 sometimes won't start on the first or second try after it's already hot. If I park and try to start it again after a few mins (fuel stop, store trips etc) it'll fire up and immediately die. It happens once or twice, the starts normally.
Could I even trace this issue without diagnostic software? Annoying bug. Any common causes?
Cheers
Old May 20, 2019 | 04:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Heat equals resistance so it can be fuel pump related or even starter related possibly...is this a "cranking no start" or "no crank - no start" ??...usually these items don't throw a DTC so some good old diagnosing would have to be done...minimum a DVOM needed to measure current flow and voltage...automotive DVOM's are usually limited to 10 amps...my fuel pump draws around 5-6 amps at idle...a bad one can draw more than 10 !!
Old May 20, 2019 | 04:48 PM
Jackie N's Avatar
Jackie N
It's a start and then a shut down, actually. It starts, revs to 1000rpm or so, and then falls right off.
Thanks for your input so far
Old May 20, 2019 | 05:01 PM
C5 Diag's Avatar
C5 Diag
MMMM ???...when it hot and not starting just turn the key ON and see if your hear the fuel pump turn on for 2 seconds and shut off....I'm thinking maybe a bad
crank sensor....also you can remove the MAF sensor connector and try to start it....see if it stays running !!
Old May 20, 2019 | 05:06 PM
Jackie N's Avatar
Jackie N
Good tips I'll try that next time I'm out
Old May 20, 2019 | 05:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent recommendations!
Old May 20, 2019 | 05:25 PM
Jackie N's Avatar
Jackie N
So if I unplug the MAF and the hot start issue goes away, what's the diagnosis? Is the MAF a culprit, or does the ECU switch functions when there's no reading from the MAF and something in that operation is faulty?
Old May 20, 2019 | 07:52 PM
C5 Diag's Avatar
C5 Diag
If there is an issue with the MAF sensor the PCM defaults to "speed density" as we call it...it's the MAP sensor !!...we have had some crank sensor issues here on the Forum lately...usually it a cranking no start...I'll usually diagnose a bad one right from the drivers seat...NO TACH movement during cranking is a good sign...yours may be on the way out...I don't like to guess about these issues but since I'm here and you're there that's about the best I can do...and that's my motto..."TEST DON'T GUESS" !!!!!
To Troubleshoot hot-start issues?
