replace spark plugs
Old Jul 10, 2019 | 10:30 PM
JBC's Avatar
JBC
7th Gear
Default replace spark plugs
when to replace spark plugs
Old Jul 10, 2019 | 10:39 PM
johnson-rod's Avatar
johnson-rod
When the thought occurs to you.
Or 10 years.
Or 100,000 miles.
Old Jul 11, 2019 | 12:01 AM
foggy's Avatar
foggy
I do half of that... Every 5 years or 50K.. Less risk of getting one seized in the cylinder head.
They are cheap, easy to do
Old Jul 11, 2019 | 11:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You will be surprised in the new idle smoothness when you get those new plugs installed. If you have never changed the wires, now's a very good time to install the GM Red Performance wires. Excellent plugs wires for the money! They fit right and will last a very long time! Very good quality wires!!
I did mine at 35K and the gaps were out of spec wide and two of the iridium pucks were missing on the electrode straps.
Old Jul 11, 2019 | 11:18 AM
MetalMan2's Avatar
MetalMan2
I'd say this is debatable. My old plug wires gave me hell, 6/8 came apart at the spark plugs, requiring huge force (with special pliers) to tear the boots off, and subsequent retrieval of the inner metal bits. Not a major problem for me since I was prepared and am mechanically inclined, but I have several "car friends" who would have given up.
Old plugs and wires were probably original from 2001, with about 62k miles, except for one random unique wire.
Also I feel like I should mention: didn't really notice any difference after installing NGK 7397 TR5IX plugs and red GM wires.
Old Jul 11, 2019 | 11:36 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Holy Hell.. Im surprised that you didn't feel an improvement as some of those wires are seriously toasted!
OP,, Make SURE that you remove the plugs on a COLD engine!
Old Jul 11, 2019 | 07:17 PM
Dave in Pa's Avatar
Dave in Pa
So which plugs do you recommend Bill? Dave
Old Jul 11, 2019 | 07:43 PM
Tenshots1's Avatar
Tenshots1
I just did this job a couple weeks ago.
1) AC Delco 41-110 are the recommended factory plugs. Cost about $40 for a set of 8 on amazon. Keep a look out for fakes that are cheaper.
2) GM Red Performance wires are an easy Amazon purchase as well. $78.
3) Job took me about 4 hours to do casually. I have giant hands, which was surely part of the problem. I heavily suggest unbolting the coil packs as a first step, as this opens up a ton of room to get to the plugs. Only takes a few minutes to unbolt, with the most annoying bolt being by the alternator. I did not use plug wire pliers but i realize they definitely would help and would suggest them unless you are really cheap.
4) Honeslty, I didnt notice a substantial benefit from doing the job. I have a 2002 coupe with 70K miles. It ran well before and well after. Looks like the previous owner changed the plugs at some point as they were an aftermarket manufacturer. I did, however, notice that my coil wires tore apart really easily. I cant imagine trying to change just the plugs, as the wires would definitely tear when trying to get them off the plugs.
Old Jul 11, 2019 | 10:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree,, The AC Delco OEM Plugs..
Old Jul 11, 2019 | 11:05 PM
Brackets's Avatar
Brackets
A little dielectric grease inside the boot on installation helps a lot with this.
Old Jul 12, 2019 | 09:25 AM
turabo87's Avatar
turabo87
If you're modded and occasionally visit Mexico or your local dragstrip, then every 5k. I've seen spark plug ceramic crack just from heat cycling with heavy duty cycle.
Old Jul 12, 2019 | 11:44 AM
GCG's Avatar
GCG
...1) AC Delco 41-110 are the recommended factory plugs. Cost about $40 for a set of 8 on amazon. Keep a look out for fakes that are cheaper...
How can one tell the genuines from the fakes?
Old Jul 12, 2019 | 12:45 PM
mfi2000's Avatar
mfi2000
Don't buy them on Amazon...land of fake stuff.. Get them from an Auto parts store.
Old Jul 12, 2019 | 01:06 PM
MetalMan2's Avatar
MetalMan2
Generally you should have no problem with fakes from Amazon as long as you buy from Amazon ("ships from and sold by Amazon") and not a 3rd party vendor.
Old Jul 12, 2019 | 01:10 PM
Dave in Pa's Avatar
Dave in Pa
Good info; Thank You Both!! Dave
Old Jul 12, 2019 | 05:27 PM
JWM's Avatar
JWM
ACDelco 41-162 replaced 41-110 on all models 2014 and older.
Old Jul 12, 2019 | 08:47 PM
Rexde1's Avatar
Rexde1
Thats exactly how it went with mine. The plugs were easy, the wires not so much and it ran about the same.
To replace spark plugs
Old Jul 14, 2019 | 11:31 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I bought a dump truck recently with a 366 Tonawanda. The wires on that we're in bad shape. Made the ones in that picture above look like they had a lot of life left. I expected a major change in the way the engine ran after replacing them and putting in new plugs. I honestly couldn't tell. That's almost inconceivable but somehow it was still sparking.
Old Mar 26, 2024 | 12:38 AM
douglasjre's Avatar
douglasjre
You're missing the boot insulator caps....
Old Mar 26, 2024 | 02:41 AM
MetalMan2's Avatar
MetalMan2
Woah, bumping a 5-year-old thread for this!
They're simply not pictured... all that's shown here is the carnage.
