02 C5Z Head Removal Help
https://www.corvetteforum.com/forums...ow-to-use.html
https://ls1tech.com/forums/generatio...ngth-help.html
https://ls1tech.com/forums/generatio...rior-ls7s.html
https://www.youtube.com/watch?v=EeQT_vA7wKI
This is great. That video from Katech is helpful in understanding the measurement process. My heads are currently off, though. What's the best method to measure while the heads are off, or do I need to wait until I have everything bolted back together?
That LS7 vs Morel lifter thread is informative. I think I'm going to stick with the LS7 lifters, the camshaft I'm running is fairly mild (http://www.compcams.com/Company/CC/c...csid=1400&sb=2).
So when I was removing the heads awhile back, one single bolt (smallest, on top of the block) on the passenger side gave me some grief coming out at the very end (top) of the thread. The bolt felt like it was free, but somehow wasn't letting go of the threads at the top. I ended up applying minimal force by pulling upwards slightly on the bolt, and it eventually caught and came out successfully. The bolt had no thread residue or shavings on it, and the entire way out other than the very end it felt normal.
I'm now cleaning out all of my threads in preparation to re-install the heads, and I'm realizing this bolt hole/thread is being stubborn and not allowing me to hand torque any of the old bolts (created a chaser bolt with dremel, doesn't like that either) or my new ARP head studs.
Any suggestions? I've read on some other forum posts that installing ARP head studs, which I already have, will usually catch even on bad threads. In my case, it seems to only be the very top of the thread that's having issues.
It's bolt #24 if that matters.
If you can not easily thread in the new studs, clean some more and try again.
REMEMBER,, there can NOT be any liquid or debris in the bottom of the hole or you will damage the block when you bottom out the fasteners. The studs have an allen hole on top of the stud to help get the stud in the block. You shouldn't have to use too much force to get the stud into the hole and bottomed out. Measure the hole depth and mark that depth on the studs so you know when you are at the correct depth. If you have to, clean up an old bolt and run it in and out of the hole to be sure that its able to fully seat at the bottom of the holes.
ARP 912-0001 Thread Cleaning Chaser, M8 x 1.25"
The pushrods are already 7.425, but I just recently purchased a COMP Cams pushrod length tool that I'm going to use to measure. I'm planning on going with a preload of .100 with LS7 lifters (what BTR recommends).
I just tried to turn the engine over again with the coil packs disconnected and had zero oil pressure again. Not even a budge on the mechanical gauge. When I disconnected the mechanical oil pressure gauge, there was no oil residue anywhere.
How could this be possible? I figured if I installed my Melling high pressure oil pump incorrectly or pinched the O ring — both which I was very careful with — I would at least have some pressure. I’m getting absolutely none. It seemed to only fit inside the gears on the crank one way, so I don’t think I could have missed that, or even installed everything else if this was wrong.
Thoughts?
Thoughts?
Did you fill the oil filter before installing it back on??
I installed a new cam, but it was a replacement for the exact same cam so same specs.
Ive turned the engine over for a total of probably 10-15 seconds with the coil packs disconnected monitoring oil pressure which never seems to come.
Changing the filter is probably a good idea, although prior to this work it was fine.
If you put a pin hole in a soda straw above the liquid level and try to suck the liquid out of a can, all you will get is air. Same principal.
The ONLY other thing it can be is a stuck open pressure regulator slide valve inside the pump. I've see a brand new pump fail because the slide valve piston bore was not machined properly and when the piston went open to regulate pressure it stuck open. We could duplicate the failure by manually pressing the slide valve to the open position and it would stay open and not slide shut on its own. They can also get stuck open if there is debris in the slide valve opening. If you get ZERO pressure in the mechanical gage, STICK A FORK IN IT..ITS DONE, Tear it back down and asses the failure mode.
ON A SIDE NOTE and I was so paranoid about my ZERO OIL PRESSURE symptoms, (caused by an electrical issue) after the second tear down, and needing to insure that the O RING was good.. I Ran my engine with the front cover off for long enough to see pressure on the gage. YES, it works and it wasn't as messy as one would think.
Call me if you need to.
Bill
Bill
Thank you everyone for their time and help on this project. The last piece I need to fix is a bad knock sensor which I believe is because I broke the lip of the sensor off while trying to remove and inspect the cam via valley cover. I'll be replacing both sensors and wiring harness this weekend to remedy my P0327 CEL.
