s WD40 02 sensor safe?
Old Jul 28, 2019 | 11:58 AM
royal flush's Avatar
royal flush
Default s WD40 02 sensor safe?
code 1416 popped up
Old Jul 28, 2019 | 12:05 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
On the threads, but a much better choice for loosening fasteners would be PB Blaster.
Dont let anything including water get into the O2 bulb/sensor area.
Old Jul 28, 2019 | 12:30 PM
royal flush
With code 1416 is it safe to squirt WD40 into hose to loosen check valve ?
Old Jul 28, 2019 | 01:40 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Those two valves have been subjected to 20 years of extreme heat cycles.
I wouldn't waste time with what is a bandaid at best. I’d replace both valves.
Better yet, I’d remove the entire smog system and tune that code completely out using hptuners (which is what I did).
Those valves are only there to allow air from a smog pump to enter the exhaust manifold when the coolant is below 130 degrees on a cold startup. It creates a lean condition and lights off the catalytic converters sooner. So in reality that entire system isn’t really needed for the overall function of the car, only to satisfy a government mandated “every little bit helps” stance on pollution.
Old Jul 29, 2019 | 02:14 AM
Simtech's Avatar
Simtech
Not sure if it is O2 sensor safe but I used it on my stuck air valve several times and haven't had any problems. I was able to put off changing the air valves by a couple of years. I would definitely tune them out if I had access to HPtuners. The car will smoke some when you start it up after using the wd40.
Old Jul 29, 2019 | 10:59 AM
royal flush
[QUOTE=Simtech;1599858883]Not sure if it is O2 sensor safe but I used it on my stuck air valve several times and haven't had any problems. I was able to put off changing the air valves by a couple of years. I would definitely tune them out if I had access to HPtuners. The car will smoke some when you start it up after using the wd40.[/QUOT--------------------------------O I used about half a can--blew air thru--let it sit overnight --erased 1614 code--drove around started afew times when cold engine--No codes--must be 02 safe--
Old Jul 29, 2019 | 05:18 PM
Moved to C5 Tech.
Old Jul 29, 2019 | 11:09 PM
hornet7's Avatar
hornet7
Default Code 1614
You’re doing it wrong. What you need to do is disconnect the A.I.R ports on the exhaust manifolds, both sides, this will prevent any solvents from contacting the O2 sensors. While the engine is still warm and the ports disconnected, plug up both sides of the air tube and spray a generous amount of cleaner like Barrymen B12 Chemtool, or any cleaner that will dissolve carbon build up, use some light compressed air to get the cleaner to soak the check valves and allow it to set over night. In the morning, unplug the passengers port and inject some compress air in the driver’s port to blow out all the crap. You will see the junk that has been built up over time on the other side of the tube. It did this from a write up from Bill curry did however I cannot find it.
Old Jul 30, 2019 | 07:19 PM
royal flush
I unplug the hose going to the drivers side check valve---spray WD 40 goes to 2nd check valve
Old Jul 31, 2019 | 02:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Answered another post similar to this one..
I started the WD-40 check valve referb procedure. Not knowing how GM designed the guts of that Check Valve, I figured that there was a sturdy disk valve with a seat that was just dirty and needed to be cleaned and lubricated.
SO,,,,,,,,,,,, Needing to know what was really happening, I dissected one.
NOTHING like I pictured in my technical brain! :-(
GM used a thick rubber disk to control A.I.R. Pump air flow. When the pump runs, it BENDS the rubber disk to allow the air to flow around it. The PCM needs to see a very specific change in O2 sensor readings when the pump is running. If it doesn't, the code is set.
The problem comes after the rubber disk is exposed to heat, carbon, AGE, and wear and tear. The rubber disk either doesn't bend enough to allow enough air around it to satisfy the test OR just no longer seals.
So, if the WD-40 treatment works, its only a temp Band-Aid.
If GM used a quality poppet style valve with a quality fiber disk and teflon seal, cleaning the valve would easily resolve the issues.
YES, this will provide you some time before you have to actually change the valve/s but like just like JOSH stated, it ONLY A BAND-AID solution. I have since, deleted my AIR system.
Bill
To s WD40 02 sensor safe?
