Cigarette Lighter convert to ignition switched
Old Mar 5, 2022 | 12:48 PM
Mark Ehle's Avatar
Mark Ehle
Default Cigarette Lighter convert to ignition switched
I would like to convert my cigarette lighter ports from always on to on when the car is on. Has anyone ever done that? I would like to leave my USB chargers in all the time.
Popular Reply
Mar 7, 2022, 07:55 AM
Simtech's Avatar
Simtech
Here is what I did complete with pictures.
First get one of the add a fuse things from Walmart or autozone. I then pulled fuse 1( cnsl cig) and 7(c/ltr) in the footwear fuse box. Next I used the add a fuse thing and made a pigtail for it to feed 2 fuses, I plugged it into fuse 11 (asryoff) then plugged the duel pigtail leads into fuses 1 and 7 on the load side. My car has been like this for years and has had no problems.
Fuse box layout
Number 11 fuse removed to show where it is because add a fuse covers things up
New harness installed.
Old Mar 5, 2022 | 01:25 PM
mmartinez's Avatar
mmartinez
Never heard about doing that, you would need wiring diagrams to find out where the cigarette lighter wires originate and move them to a switched power source.
Old Mar 5, 2022 | 02:16 PM
Mark Ehle's Avatar
Mark Ehle
Well, I was thinking about pulling the fuse that runs them and making a small wiring harness from that fuse to switched power somewhere. I just wondered if there might be an easier way.
Old Mar 5, 2022 | 02:22 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
You could interrupt the cigarette lighter power wire with a 12v relay using the normally open contact. Just connect the relay control to a switched 12v power source. There's a wire available near the BCM in the passanger footwell for this unless it's a 2004, then you have to find a connection at the fuse box.
Old Mar 5, 2022 | 10:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just purchase an ADD A FUSE pig tale adaptor to a 20 amp fuse in the fuse box , from an ignition powered fuse (most likely a 20 amp circuit) and run a wire from that TAP to a dedicated owner installed CIC LIGHTER Adapter. You can install it where ever you like....
BC
Old Mar 6, 2022 | 08:39 AM
Mark Ehle's Avatar
Mark Ehle
BC
Now that sounds like something I had in mind, but I didn't know what those were called - Thanks!
Old Mar 7, 2022 | 07:55 AM
Simtech's Avatar
Simtech
Fuse box layout
Old Mar 7, 2022 | 08:02 AM
Simtech's Avatar
Simtech
Just looked up what "ASRYOFF" fuse is for and found this. I looks like it is not used.
Originally Posted by lucky131969 View Post
There are three taped/stowed wires in the BCM area: Black, yellow, orange. Orange is hot at all times, yellow is switch with ignition, black is ground. Fuse 11 is for the yellow wire. Provided for accessories.
Old Mar 7, 2022 | 08:41 AM
Mark Ehle's Avatar
Mark Ehle
Simtech - YOU ARE THE MAN!! This is exactly what I need. Thanks so much for the pictures and the info! And thanks to all the others for your help, too.
Old Mar 7, 2022 | 08:59 AM
Mark Ehle's Avatar
Mark Ehle
So Simtech, the connectors on these wires are just spade lugs then?
Old Mar 7, 2022 | 09:26 AM
Simtech's Avatar
Simtech
I honestly don't remember so I went and pulled one of them out real quick and it looks like I may have cut up a fuse and used it.
Old Mar 7, 2022 | 09:32 AM
Mark Ehle's Avatar
Mark Ehle
Ah - OK. Hey, thanks so much!
Old Dec 29, 2022 | 05:19 PM
Ferd-C5's Avatar
Ferd-C5
3rd Gear
Hey Simtech, thank you so much for a brilliant post! I just finished the conversion on my C5, and it is exactly what I wanted: I can now leave things connected to the lighters without draining the battery even faster than it already does!
Old Dec 30, 2022 | 01:34 AM
Justin Raney's Avatar
Justin Raney
Fuse box layout
You converted the cig lighters powered on all the time not just when car is on? All you had to do was add the add-a-fuse or wire adapter removed both the original cig lighter fuses and ran that wire thats hot at all times to both lighter circuits? How did you figure out which side or terminal on the fuse was the correct wires to the cig lighter? The load side is the one with the end circuit for what it powers correct and not the supplied power or ground circuit?
Old Dec 30, 2022 | 08:20 AM
Simtech's Avatar
Simtech
No, this hooks the cigarette lighter to the acc. circuit making it on only when the car is on. As for figuring out which side of the fuse is the supply side you just pull the fuse and check for power, the side that still has 12v is the supply side.
Old Dec 30, 2022 | 12:27 PM
Justin Raney
I thought he said try to wire the cig lighters so theyre on all the time to charge phone when the car is off. Yes they do stay on all the time i seen that with the usb charger, bluetooth, voltage reader i use for blue toothing music to the cars radio channel with phone.
I need to see whats wrong with the upfront cigarette lighter on mine only the one in the center console works. Its fuse 1 and 7 and which is the front cig lighter by shifter and which is the cig lighter in the console so i can check that its getting power before replacing the dc socket as it requires console removal.
fuse 1( cnsl cig) and 7(c/ltr) in the footwear fuse box?
Old Jul 1, 2023 | 01:09 AM
emsteph's Avatar
emsteph
Default 100% Agree
I echo this sentiment.
To Cigarette Lighter convert to ignition switched
Old Jul 24, 2023 | 05:40 PM
Saint n Soldier's Avatar
Saint n Soldier
Fuse box layout
Thank you so much for this tutorial! It worked like a charm
Old Apr 19, 2024 | 11:16 PM
Bigmik1021's Avatar
Bigmik1021
Thanks for this. Quick, simple, and easily reversible. Doesn't get better than that!
Old Apr 20, 2024 | 09:45 AM
lucky131969's Avatar
lucky131969
Unless your charger has an led light(which draws next to nothing), it will not draw current unless a device is connected.
