Excessive Blowby?
https://www.corvetteforum.com/forums...02-c5-egr.html
explain why I've never seen or heard of it I guess
So that port is NOT for EGR.
Lots of engines including supra, skyline, silvia, corolla, etc... all use a port like that to feed the crankcase fresh air. On the LS1 intake it is simply moved to just before the throttle body instead of part of the intake plastic duct work. I show a picture above from the service manual and have tested it on my own intake. As I said I blocked it because of boost pressure. Its just an open hole that leads from air filter to crankcase and my filter was replaced with intercooler cold pipe.
Good call, thanks for paying attention, we appreciate you. The port in the plastic duct may indeed be blocked as it is NOT used for PCV. However the true pcv port is merely inches away attached near throttle body and should not be ignored as it provides fresh air to crankcase in a similar fashion as if it WERE connected to that location on the duct.
Here is the blocked PCV fresh air supply in my video
1:28 you see the missing bolt is a boost leak
This is the crankcase breather for stock intake without forced induction
If i understand what he is asking, My IQ is 56
and im proud of it.
And yes im talking about N/A cars.
This is what GRINDER III emailed me so this is not me. I copied and pasted this. His quote, don't hold it against him he, was over half in the bag.
He just doesn't want to be hated on here by other members
And, not to nitpick. But. There are a couple other things influence blow-by.
High crankcase pressure causes excessive blow-by. Its a positive feedback loop situation, more blow-by, more pressure, reduced ring function, more blow-by, more pressure, reduced ring function, etc...
Crankcase pressure forces the piston ring up earlier in the power stroke. Its called early ring switching. The ring force is balance by inertial forces and pressure forces, this situation of high crankcase pressure may leads to ring flutter which carries oil into the ring pack, causing even further reduced ring function, over time buildup causes more and more blow-by and more crankcase pressure.
If people want really clean, nice, well sealed up piston rings? Want a great piston ring seal? Measure crankcase pressure and Shoot for 0.5" to 1.5" Hg pressure drop at WOT to protect ring function.
https://www.youtube.com/watch?v=0oRbfNPnHaI
For street apps however vacuum pumps are un-wanted additional maintenance and complexity. For somebody like me who drives 10k/year non-stop I don't wana rip the front of my car apart for any reason, not even an alternator.
And if you are using a very quiet, high pressure exhaust system like OEM noise level, it is often too much pressure to evac effectively to exhaust. I've seen hit and miss success... it may become potentially unreliable in some cases.
This leaves only electric vacuum pump option and air filter pressure drop option. The electric pump has its own set of issues, the fuse may blow, it requires monitoring and a warning system for when it stops working. They also have mixed results running the pump full-time, some burn up, etc... mixed bag. Can be done but requires more setting up and potential for maintenance issues.
Which brings us to the OEM solution: air filter pressure drop. Very simple. Cannot be defeated easily, will not suddenly fail or turn off. Functions well with a restrictive exhaust system. Just needs an initial setting up, you measure, adjust, and its done for 200k miles as long as nothing really changes with the setup.
Power is related to CFM flow pressure drop at the filter so for example if I turn up the boost from 500 to 600rwhp the CFM demand increase will create additional pressure drop. Which isn't an issue- its just worth mentioning that the air filter solution entails knowledge of CFM flow rate demand at WOT to be setup correctly.
