C5 headlight question
Old Sep 30, 2022 | 12:30 PM
Max2fat's Avatar
Max2fat
Default C5 headlight question
Have an annoying drivers side headlight that goes up and then pops up again half way and only will go down when I manually get out and turn it down - any recommendations Thx Max
Old Sep 30, 2022 | 01:45 PM
3sACROWD's Avatar
3sACROWD
There are 4 white bumpers per headlight. They could be worn or missing. Verify they are there. If one looks worn (The indentation may be too deep), flip it over.
Old Oct 1, 2022 | 07:44 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
4? I've always thought 2. Good to know.
But yes sir, you are correct. That is a sure signal one is missing.
Old Oct 1, 2022 | 08:46 AM
3sACROWD's Avatar
3sACROWD
Yes. Two of them are at the rear of the assembly just under the cover and can be seen if you open the hood and 2 that the actuator arm contacts. Usually the actuator arm ones wear out or fall off.
Old Oct 1, 2022 | 06:16 PM
corvettezman
They're too cheap to filp IMHO, but for a temp fix . Last I saw, they were like $9 a pair.
Old Oct 1, 2022 | 07:55 PM
Dave68's Avatar
Dave68
Have you checked the plastic gears? I switched mine to brass after one of the plastic gears broke some teeth.
Old Oct 2, 2022 | 10:45 PM
Moved to C5 Tech.
To C5 headlight question
