Changing brake fluid
For those reporting rusted pistons I have to ask if you're the original owner of the car. If your answer is "no", you quite simply don't know the history of the vehicle. Some previous owner / dipshit / dipshit mechanic might have left it parked with the brake fluid res cap sitting off for weeks, months, or years and caused serious water absortion. You simply don't know...
I've run vehicles from 250k - 500k miles with the original brake fluid. Never had a single hydraulic problem that wasn't caused by a brake booster or master cylinder seal failure EDIT: or a cut brake line.
BTW, I have done quite a bit of work on the car in my own garage. I removed the engine and transmission years ago and installed the double row cam chain to bring it up to date. That was probably 10 - 12 years ago. Not my first rodeo with autos.
As I alluded to previously, I've owned two GM vehicles and one VAG (Volkswagen / Audi) that I've purchased new or second owner that had original brake fluid that survived > 10 years or 245k miles and never had a hydraulic issue. In fact, the Volkswagen still had the original brake fluid in it at 506k miles when the booster seal failed and subsequently destroyed the master cylinder seal.
If you want to change your brake fluid regularly I'm not discouraging that, only pointing out that it's utterly and completely unnecessary.
FWIW
All this is essentially irrelevant as you're not the OP (original poster). I'd like to commend you on your ability to do your own wrenching, but you otherwise present nothing useful to the subject. In fact you're boasting working on a vehicle from a different manufacturer and from a completely different era. I understand that my attitude is abrasive, but what exactly is your point (rhetorical question). The fact that you own a sports car doesn't somehow make the laws of physics different.
If you want to change your brake fluid regularly I'm not discouraging that, only pointing out that it's completely unnecessary.
FWIW
FWIW
If you're planning to take your car on a racetrack , please flush your brakes. Your mileage probably won't vary.
Phoenix Systems BrakeStrip Brake Fluid Test Strips 3001-B
Yes there are a number of brake fluid moisture analyzers available, here is one:
Whether any of them are reliable or accurate, you have to read the reviews.
As for those that seem to love old brake fluid, well, more power to you. You're probably the same as the ones who never ever flush power steering, diffs, transmissions, or anything else other than oil. Just because it keeps working with that old garbage fluid doesn't mean it's the right thing to do, and judging it by the fact that, by dumb luck, you haven't experienced a failure again isn't proof that it's the right thing to do. If you truly believe that, I challenge you to start neglecting engine oil changes and let me know how that works out.
You can buy a New Master with a new reservoir fairly cheap. OR if your smart enough Master cylinders are fairly easy to rebuild then clean your reservoir before Bench bleeding.
I never drain mine if they are dark I replace it, With new or rebuilt unit after bench bleeding install it. Then continue to bleed all Calipers in order till each runs clear fluid out of it.
, and always replaced with clean fuel, which doesn't deteriorate unless car is stored. So not all of us ignore everything, though some probably do. Brake fluid (nope).
EDIT: Forgot about the power steering. In the 3 cars, and nearly 1 million miles I posted about earlier, I've never bled/changed that, either. I have added fluid to the C5s power steering reservoir when I've changed cams, and lost some due to the rack being removed. But car still steers fine, and easy, with no leaks or hydraulic "moaning." So did the other 2, 400,000 mile Buick, 360,000 Jeep GC.
Based on your posts filters get more efficient as they collect impurities and you never change fuel filters. But air & transmission filters get changed even though they get more efficient as they become clogged. And unfiltered things like rear end, brakes, and power steering don't get changed because... reasons.
As someone reading your posts I'm not able to apply your advice to other situations since they don't seem to make sense.
