Changing brake fluid
Based on your posts filters get more efficient as they collect impurities and you never change fuel filters. But air & transmission filters get changed even though they get more efficient as they become clogged. And unfiltered things like rear end, brakes, and power steering don't get changed because... reasons.
As someone reading your posts I'm not able to apply your advice to other situations since they don't seem to make sense.
Here's the problem.....when wanting to empty the reservoir, to fill it with fresh fluid, there's no way to draw fluid out of the front sump. The divider prevents the turkey baster from getting in there, and it's too low to get anything like small tubing under it. As crazy as it sounds, I tried jacking the front end of the car, hoping the slant would get the fluid to run rearward, but that didn't work, either.
As a last resort, I've used my Motive bleeder to pressurize the reservoir, and as carefully as possible, bled the sump down really low, but I'm afraid to get air in the system, so there's always a little residual fluid left, so I don't get a 100% flush. What's everybody else doing, to get around this?
es, you'll never experience the turkey baster issue again. Just a suggestion, and you have a great tool in the Motive tool. Should be pretty easy. I'd like to know whether this would work, or my suggestion sucks, and it might. Just trying to help, so don't shoot the messenger!!!
With respect to SpeedBleeders, I don't care for them. While in theory, they're a great idea, in practice, they don't work all that well, over time. The reason is that for them to work properly, the thread sealant that's used on them has to provide a 100%, air tight seal with the caliper. They will............for the first couple of times that you use them. But over time, the sealant begins to "conform" better to the threads of the caliper, and no longer seals tightly. This allows air to be drawn past the threads, and back into the caliper, defeating their purpose.
that said, filling up with gas has the highest statistical probability of inadvertently contaminating and/or clogging your system (and you have zero control over that unless you personally test every batch before pumping into your car). and you ask, "what's the worst that can happen with clogged fuel?" it clogs while you're zipping up an on-ramp to make the hole in traffic or while you're trying to pass someone before the lines change back to double-solid... high-load fuel pressure loss is an easy way to blow a piston.
as for other systems that don't have filters - many often have pressure vents and/or weep ports. it is possible for dirt & grime to enter the system through those orifices. additionally, as metal parts wear (especially if under high load), they often tend to shed fine little bits of themselves. i prefer to not perpetually circulate metal flakes/dust through tight clearances.
both times, i recognized the issue and never gave it hard throttle. i tend to change mine on 15k mi intervals.
i honestly don't remember where i filled up with the bad batch, and i don't live there no more anyway, so it don't matter. gas stations are independently-run franchises, so just because my local exxon station, for example, don't maintain the tanks like they're supposed to & gets algae, dirt, etc. in their gas... that don't mean all exxon gas is the devil. on a bigger scale, say one new england exxon refinery screwed something up & distributed a bad batch; exxons west of the mississippi likely won't ever see that fuel.
OMG!!!!!! really???? I cant believe ANYONE would publicly suggest that to anyone????!!!! Please any one reading this do not do this to your master cylinder!!!!!!!
REALLY ?????
You like so many other people on this web sight REALLY think you know more than REAL Auto engineers and real mechanics on this web sight.
So many of you should keep your mouths shut and Just read and learn!!!!! I been working on cars for over 40 years and their are subjects I still never comment on And Just read!!!!
You have no idea why the divider is their or what its for or why the two are divided for do you ?????
Why any one that does know would suggest this???? do you really want to get people Killed????
That's an Insane suggestion you clearly have No idea what you are talking about,
Please Stay off PUBLIC Highways with ANYTHING you have worked on or Modified.
Your publicly stating that you drive at 130 mph with anything you have worked on is a scary thought.
YOU Sir are correct!!!!! What this Moron suggests will get some one killed!!!!!!!! AND Ya I am Calling Him a MORON PUBLICLY!
PLEASE Do not do what this guy suggested to your Master cylinder.
This guy should be banned for Giving bad advice that will get someone killed he has no idea what he is talking about and should be permanently suspended from ever posting again!
He is No Mechanic he is nothing more than a dreamer wanna be he should keep his mouth shut hes giving BAD advice and suggestions!
He should be forever permanently prevented from ever posting again on the forum.
Telling people to do a Modification to their Master cylinders that will kill people... I still cant be leave it.
REALLY ?????
Used it when converting the old truck to front disc brakes.
Maybe a few months later the hose on the motive bleeder rotted off, it was inside garage so maybe brake fluid ate it up, this is the hose on the outside of the tank that connects to your adapter lid for master cylinder.
Guess I’m a
Try posting some evidence to back up your claim. At least @grinder11 posted reasons for some of her or his practices. That allows you to make an informed decision.
If you think the additional hole is problematic post the reason why you think that and the evidence to back up your claim.
Guess I’m a
If you're that set on perfection, your bleeding regimen should start with seating all the calipers to remove any stagnant fluid contained in them, where it is most likely to experience boiling temps. Who's thought of that one?
Supercharged - not to refute your assertion about wet fluid becoming corrosive, but I live in the rust belt. The shops I know who replace rusted brake lines are doing so because of salt and calcium chloride collection in areas under the vehicle. Show me some one owner cars that live in latitudes below 35* who've experienced brake line rust through and I'll proclaim that everyone should change their brake fluid at least annually.
C'mon guys, let's be reasonable.
I think you would get a more direct answer if you were more specific. Are you tracking your car(s)? If not the premise of your question is somewhat ridiculous.
It's my strict assertion that leadfoot4 is either leaving out important details such as frequent track days, or he's being very extremely paranoid. Whatever the case, the correct answers will vary.
I thought that I was asking a simple question, with the thought that I was simply overlooking something in the process. I guess not....
