Changing brake fluid
Old Jan 4, 2023 | 08:39 AM
  #61
DanA_F99_1977's Avatar
DanA_F99_1977
2024 C7 of the Year Finalist - Unmodified\
I am almost afraid to post in this thread.
One thing to remember if you want a complete flush is the antilock brakes. You need a tech 2 to in order to release that fluid.
I bleed every few years but I am a little extra careful with maintenance since I take longer type trips. I don't worry about the ABS module. It is such a small amount I am happy with just replacing what fluid I can using my brake bleeder.
I use the ranger method for my clutch only because I can't deal with the bleeder. Someday when I need to do clutch I will get a remote bleeder.
My thought on this is that brake fluid does absorb water. The manufactures don't even suggest you use an open bottle. They sell it in small bottles so you use what you need and discard the rest and always use a fresh bottle.
Maybe extreme but that is what they say.
Old Jan 4, 2023 | 10:32 AM
  #62
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I don't have a Tech II, so I'm faced with that dilemma. What I do, however, right after I flush what fluid I can, is to take the car out on a wide grassy area, that's near my house, and activate the ABS a couple of times. Hopefully, that sends clean(er) fluid through the ABS block.
Old Jan 4, 2023 | 11:21 AM
  #63
SouthernSon's Avatar
SouthernSon
Originally Posted by E46Pittsburgh
I use my Motiv bleeder "dry" rather than wet - I add fluid to the car reservoir only and then pressurize with the Motiv. Saves time for cleanup but you need to pay attention to fluid levels.
Exactly, I don't use enough fluid to keep the motive filled up with relative fresh. I am through with this thread. Too many really trying to make an issue out of something that has never been an issue with me. To each his own.
Old Jan 4, 2023 | 12:03 PM
  #64
leadfoot4's Avatar
leadfoot4
Originally Posted by SouthernSon
........... I am through with this thread. Too many really trying to make an issue out of something that has never been an issue with me. To each his own.
Understood. I thought i was asking a relatively simple question....................
Old Jan 4, 2023 | 12:19 PM
  #65
spfautsch's Avatar
spfautsch
For what it's worth, I just manually bled mine after repairing the two rear lines and replacing the two hard lines from the master to the ABS / BPMV with new braided -3an lines.
It took a good bit before the air got to the right rear - maybe 10-15 cycles. The left rear took another 8-12 before the air got there. I then went through about another half a liter on the fronts, and didn't get a single air bubble. So I'm skeptical the BPMV and pump aren't adequately purged by simple manual bleeding with the pedal.
I do know the FSM doesn't mention anything about activating the ABS for bleeding. I haven't looked to see if there's another procedure for ABS replacement / fluid exchange.
Old Jan 4, 2023 | 12:27 PM
  #66
Supercharged111's Avatar
Supercharged111
Would this not also negate the ability to keep brakes on one circuit if you ruptured a line?
Yes it would, it is a TERRIBLE suggestion for that reason. All cars are designed this way for that reason.
Originally Posted by spfautsch
Wow, this thread really ran off the rails. It seems like this happens a lot when questions are asked without sufficient background and specificity.
I think you would get a more direct answer if you were more specific. Are you tracking your car(s)? If not the premise of your question is somewhat ridiculous. The only racing I do is when some moron in a lifted Silverado with offset rims wants to challenge me. Even then, after as far as I could drive as fast as I was able to, I still didn't experience brake fade even after I crested a hill to find I was running up on a line of cars that were moving approximately 100mph slower than I was right after a hard sweeping 90. The only thing that faded was the possibility of wearing my underwear to bed.
I probably made the most pointed defense of old brake fluid. And when I say old, I mean wet. I'm not advocating that wet fluid should be in a car you plan to track. But the street is not the track. It doesn't matter if you drive a Corvette, or a Chevette. It's my strict assertion that leadfoot4 is either leaving out important details such as frequent track days, or he's being very extremely paranoid. Whatever the case, the correct answers will vary.
If you're that set on perfection, your bleeding regimen should start with seating all the calipers to remove any stagnant fluid contained in them, where it is most likely to experience boiling temps. Who's thought of that one?
Supercharged - not to refute your assertion about wet fluid becoming corrosive, but I live in the rust belt. The shops I know who replace rusted brake lines are doing so because of salt and calcium chloride collection in areas under the vehicle. Show me some one owner cars that live in latitudes below 35* who've experienced brake line rust through and I'll proclaim that everyone should change their brake fluid at least annually.
C'mon guys, let's be reasonable.
Old fluid, of any kind, is no good. It can be broken down, contaminated, etc and should be changed out. Hell, even engine oil turns acidic with time and little use and shoudl be changed. Using the line of reasoning that the car still stops doesn't mean it's right. You can keep using any neglected thing up to the point of failure, that's hardly the point. The point is fresh fluid is always better than 20 year old neglected fluid. And the corrosiveness has nothing to do with rotting a line through in the rust belt and everything to do with how it can attack the surfaces it actually comes into contact with. I'm being very reasonable here, can't say the same for everyone else in here. It blows my mind how a bunch of people who likely obsess over a 3000 mile oil change would not only be happy to neglect other areas of the car, but to defend it.
Old Jan 5, 2023 | 11:28 AM
  #67
romandian's Avatar
romandian
just recently i found a jar with old brake fluid i put aside long ago and forgot (lid was "tight)". just for fun i checked the boiling point. it was around 200°f.
to op: put a piece of hose (pvc, rubber, silicone) on the styringe and suck i as dry as you wish.
Old Jan 5, 2023 | 12:01 PM
  #68
leadfoot4's Avatar
leadfoot4
Originally Posted by romandian
to op: put a piece of hose (pvc, rubber, silicone) on the syringe and suck i as dry as you wish.
Tried that, last year. There's not enough space between the "divider" in the m/c and the bottom of the m/c, to get any tubing through there.
Old Jan 5, 2023 | 12:42 PM
  #69
E46Pittsburgh's Avatar
E46Pittsburgh
just recently i found a jar with old brake fluid i put aside long ago and forgot (lid was "tight)". judt for fun i checked the boiling point. it was around 200°f.
Is that good enough for stops for 130mph?
Old Jan 5, 2023 | 12:45 PM
  #70
Supercharged111
What if you bend a small section of brake line specifically for this? Attach it to your sucker with a vacuum line. I think I want to try that myself now.
Old Jan 5, 2023 | 04:54 PM
  #71
leadfoot4's Avatar
leadfoot4
I was hoping to do that, and I bought some really small ID tygon tubing and super glued it to the nozzle of a plastic syringe. Since there IS a certain amount of liquid transfer between the front and rear chambers of the m/c, obviously there is a gap, somewhere near the "floor" of the m/c. However, (a), I can't seem to find it, or (b) it isn't big enough to get anything other than liquid through it. That's why I originally posed the question here.
Old Jan 5, 2023 | 04:59 PM
  #72
Supercharged111
The only way the 2 chambers share fluid is when the level is taller than the vertical cut in that wall that separates them. I'll have to take a closer look at mine when I get home, it could be that the filler neck hangs low enough to overlap that wall and just block you out completely. At any rate, the way I've been handling it so far is to simply push more brake fluid through so the crap you can't suck out of the reservoir eventually gets pushed out of the caliper downstream. You could secure that tubing to a piece of Mechanic's wire so it holds its shape too.
Old Jan 5, 2023 | 05:09 PM
  #73
spfautsch's Avatar
spfautsch
Though I don't think it's necessary for a car that isn't tracked, supercharged's hard line idea may be a good one. Another thought, I have a bunch of marinade injectors I keep in the shop for stuff like this (more often for injecting grease) with 0.115" needles. I just checked and it will pass into the slot for the front reservoir. Though I'm not sure if I'm fully understanding the divider layout as I've never drained mine.
Old Jan 6, 2023 | 09:37 PM
  #74
spfautsch's Avatar
spfautsch
Here's a marinade injector kit with an extremely long Quinke (simple angle) cut needle. I bet it would reach into both reservoirs through the slots in the filler volute.
Meat Injector Kit Stainless Steel Food Syringe & 3 Marinades Needles Meat Injector Kit Stainless Steel Food Syringe & 3 Marinades Needles
Old Jan 7, 2023 | 07:56 AM
  #75
leadfoot4's Avatar
leadfoot4
I doubt it. You have to have some sort of tube, on the suction side, that can both make a hard 90* turn, right after it enters the fill hole of the m/c, pass through the divider, then make another 90* turn, in order to get into the front sump of the m/c.
Old Jan 7, 2023 | 10:42 AM
  #76
spfautsch's Avatar
spfautsch
I see what you're saying now. Sorry hadn't looked very closely at the reservoir from the side.
This was my thought, but obviously that will end up destroying the float for the float switch.
Full res here
I wonder if drilling a 1/4" hole between the 12:00 and 3:00 slots in the filler volute would be workable. Then fish a curved piece of 3/16" hard line in.
Another thought that would be messy as hell - drive the retaining pins out and replace them with screws. Then just pop the reservoir off after draining with a baster.
Old Jan 8, 2023 | 12:03 PM
  #77
leadfoot4's Avatar
leadfoot4
I..............Another thought that would be messy as hell - drive the retaining pins out and replace them with screws. Then just pop the reservoir off after draining with a baster.
Classic understatement!!
