Clutch failure?
Old Feb 20, 2023 | 10:36 PM
  #41
acefominC5's Avatar
acefominC5
Originally Posted by Days of Thunder
I would still start with replacing the master first. of course your mechanics want to replace the clutch. Its a $2k job!!
Clutch weak points are master, slave or worn out disc. Spring failure would be highly rare!!
happy motoring
**** it tbh I’ll do this job anyway I wanted a lightweight flywheel for the longest
Old Feb 20, 2023 | 10:45 PM
  #42
vette4fl's Avatar
vette4fl
After buying an 18 year old car, when my hydraulics went to **** I couldn’t wait to do the whole clutch thing. And the old one was looking pretty toasty…
Old Feb 21, 2023 | 03:55 AM
  #43
acefominC5's Avatar
acefominC5
This Vette been in dozens of drag / roll races as well on the street , drift pits etc I’m surprised the clutch lasted this long
And to the guy suggesting master - the same mechanic convinced me NOT to buy a new clutch when my master failed back in the day. Kept telling me it’s the hydraulics. So I know that his takes are genuine.
Old Feb 21, 2023 | 02:37 PM
  #44
Days of Thunder's Avatar
Days of Thunder
Well, def go with a Monster TWIN disc. Replace those axle seals too!
Old Feb 21, 2023 | 03:23 PM
  #45
vette4fl's Avatar
vette4fl
The OP already stated he bought a McLeod RST.
Old Feb 21, 2023 | 03:30 PM
  #46
Days of Thunder
Mcleod is always a good second choice.
Old Mar 1, 2023 | 05:47 PM
  #47
acefominC5's Avatar
acefominC5
The car is fixed, it was the clutch. Everything is great 👌
Old Mar 1, 2023 | 09:34 PM
  #48
Johnny Hardcore's Avatar
Johnny Hardcore
Problem solved! Now be patient on the break-in then give'r hell!
Old Mar 1, 2023 | 10:06 PM
  #49
ThomasR's Avatar
ThomasR
Can you show us how your clutch failed?
Old Mar 2, 2023 | 01:11 AM
  #50
acefominC5's Avatar
acefominC5
Will answer what failed when my mechanic reaches me back.
All I know is this clutch feels great from the get go, and aluminum Flywheel did not make as big of a difference as I thought it’d make.
Revs jump quicker and bite point got much smaller.
Car is much more fun to drive for sure. Engine woke up a bit even though I haven’t stepped on it yet. Regardless it’s just as streetable as it’s ever been. If you disagree buy an automatic
Old Mar 2, 2023 | 01:29 PM
  #51
acefominC5's Avatar
acefominC5
It was the clutch fork. Clutch itself was also on its way out as well, guess all those clutch kicks took a toll on it, who would’ve thought 😂
Cant stress enough how great this new clutch feels, I’m really happy with my choice.
Old Mar 3, 2023 | 04:33 PM
  #52
acefominC5's Avatar
acefominC5
Wanted to ask y’all, what is the proper technique of letting off from a stop? Do I gas it right before the bite point and gas it out? Should the revs drop at all once it engages or am I supposed to increase gas in a way which will keep revs stable?
I’m good at stick but I want to make sure I’m doing this correctly
Old Mar 3, 2023 | 10:28 PM
  #53
666lisa's Avatar
666lisa
Don't take this the wrong way, but u just been telling us how awesome the set up is?? So why would you want to try and change the way you drive it, if you love the clutch set up??. I mean how r u doing it now??? Its subjective whatever feels good to you without smelling clutch burning. Just staying. Sounds like to me, you hit a great setup for yourself.
Old Mar 3, 2023 | 11:02 PM
  #54
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by SouthernSon
As far as rear end I would think the Quaife ....
Old Mar 4, 2023 | 08:34 AM
  #55
ThomasR's Avatar
ThomasR
I try to be as quick as I can engaging the clutch. I treat it like an on/off switch unless I'm stopped on an up hill. Then I will engage it until it bites to stop the car from rolling away will I quickly move my right foot from the brake to the gas.
Old Mar 4, 2023 | 01:09 PM
  #56
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Mechanic said it was a pressure plate spring failure. I was wrong in thinking that the system wasn’t creating pressure - it was, but that pressure does not disengage the clutch.
So yes, I will be doing a full clutch job. RST + LTW flywheel, slave cyl, remote bleeder line, throw out bearing.+ pilot bearing + driveshaft couplers
Thinking about 4.10 or 3.90 gears as well since the drivetrain is coming off. That paired with a lightweight flywheel is gonna be fun
4.10s are the bomb. Second gear screams to 60+ before you blink.
Applaud your choices and commitment. It’s gonna scoot.
I lost the spring out of the hub of the clutch, put a McLeod twin in and lost a disc on the twin. Turned out the couplers were failing.
Old Mar 4, 2023 | 05:28 PM
  #57
acefominC5's Avatar
acefominC5
Dummy I’m just inquiring about the proper driving technique. Why you so negative all the time? Go outside
To Clutch failure?
Old Mar 4, 2023 | 06:07 PM
  #58
666lisa's Avatar
666lisa
Im not negative ,i was going about what u were saying. U love the set but u want to do someone else's driving habits so to me ur looking to change ur driving but u said u love it so i don't see where im negative just commenting on what u said. Do whatever you want.. To me i might be wrong, so you can yell at me again, i have thick skin so let me have. Everybody's a little different you just have to find your.
Old Mar 4, 2023 | 08:04 PM
  #59
acefominC5's Avatar
acefominC5
You realize I’m also the one breaking the clutch in, correct? I want to do so the correct way. I don’t mind changing my driving habits if they put undue wear on the car. As I said earlier you seem negative, your takes are pretty strange as well.
Old Mar 5, 2023 | 11:37 AM
  #60
666lisa's Avatar
666lisa
Yes, your not the only one that said this, about my strange comments. I mine, r u having issues taking off from a stop?? Or you don't like the way it takes off. Just saying u changed ur set so there will be a learning curve. Sorry if im coming off negative, what i say in my mine obviously doesn't come on paper, but to me it does. Hope u find ur sweet spot.
