Throttle Position Sensor - Strange
Old Dec 13, 2023 | 08:53 AM
BIGJIM13's Avatar
BIGJIM13
Default Throttle Position Sensor - Strange
2004 Corvette
Old Dec 13, 2023 | 10:27 AM
StingrayRebel's Avatar
StingrayRebel
maybe the TPS wasn't the problem
Old Dec 14, 2023 | 12:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would say that the Sensor that you received was the wrong one..
IMHO, The Idle issue is NOT caused by the TPS.
I would be more inclined to look for a vacuum leak.
2004 LS1 has a large rubber fitting for the PCV valve that is prone to dry rotting/cracking. Its on the passengers side of the intake manifold just rearward of the Throttle Body. Look at that rubber fitting and inspect it for CRACKS/TEARS/LEAKS.
There are SEVERAL IDLE related things that need to be checked. Any non metered air that enters the engine will have a negative impact on idle quality.
Things that I would do:
1. Remove the complete AIR BRIDGE and AIR FILTER ASSY Check the air filter, clean the MAF with MAF Cleaner
2. Clean the Throttle Body and Throttle Blade.
3. Reinstall the AIR BRIDGE and AIR FILTER ASSY insuring that there are ZERO air leaks between the MAF and TB.
Give that a try and see if it runs better.
Bill
To Throttle Position Sensor - Strange
