Heads Up Display
Old Nov 17, 2024 | 12:46 PM
Farnster 2's Avatar
Farnster 2
Navigator
Default Heads Up Display
03 Anniversary Edition -
HUD has water spotting (i’m guessing) on the underside of the clear HUD panel in the dash.
Any advice on removal of the dash HUD panel surround to avoid damage? Any other suggestions for cleaning?
Any help is welcome.
Old Nov 17, 2024 | 01:03 PM
jcj63's Avatar
jcj63
Unfortunately that surround is held on with 4 push on clips under the dash. You need to remove the dash panel to get to them. Not sure how to clean that without taking it all apart.
Old Nov 17, 2024 | 06:32 PM
Farnster 2's Avatar
Farnster 2
Navigator
Thanks for your input. I’ll wait until I have another reason to get into the dashboard to address this. Not a serious problem but the HUD is cloudy in certain lighting. I appreciate your prompt response.
Old Nov 17, 2024 | 06:58 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
there was a thread on here for the procedure of removing the dash pad, I installed a Hud on our C5Z, seems like the dash was off in less than a half hour, i am a Mechanic so there's that !!
Old Nov 18, 2024 | 07:39 AM
Farnster 2's Avatar
Farnster 2
Navigator
Default Dash Pad Removal
Thanks for this information. If anyone can direct me to the C5 dash pad removal process I would greatly appreciate it. I’ve done various cars over the years and have yet to find on example that didn’t involve some unexpected and serious challenges.
Old Nov 18, 2024 | 09:12 AM
Gordy M's Avatar
Gordy M
Attached is a copy and past on how to remove it
File Type: docx
Old Nov 18, 2024 | 03:36 PM
Farnster 2's Avatar
Farnster 2
Navigator
THANK YOU GORDY !!
This is fantastic, right down to fabrication of my own tool to avoid breaking those pesky plastic tabs that are always present and always break.
This simple question and the advice it provided will keep me a lifetime member of this forum. I hope I can help someone else as much as I have been helped.
We won’t know for a while whether this works for me cause I’m not quite ready to tackle it yet. BUT, I couldn’t have asked for a better result when I raised my question about the HUD.
Old Nov 18, 2024 | 11:19 PM
Moved to C5 Tech.
To Heads Up Display
