VATS issue - need help
Old Mar 27, 2025 | 11:05 PM
  #41
PugaZ06's Avatar
PugaZ06
New TDR relay installed, so far so good.
Thanks again mmartinez.
Old Mar 28, 2025 | 04:52 AM
  #42
jdmvette's Avatar
jdmvette
Night Owl for life
^ that's awesome, @mmartinez is very knowledgeable when it comes to figuring stuff like this out
Old Mar 28, 2025 | 09:49 AM
  #43
mmartinez's Avatar
mmartinez
Your Welcome, always willing to help a fellow C5 corvette owner.
Old Mar 28, 2025 | 02:23 PM
  #44
Monty23's Avatar
Monty23
Originally Posted by mmartinez
It's VATS, which is built into the BCM, consists of the resistor key pellet reader in the Ignition switch which enables the BCM to provide a ground to the TDR. Don't know much about HP tunners but turning VATS off is disabling the input from the BCM to the PCM to allow fuel delivery.
Correct, you still get the error on the dash even with VATS turned off using HP tuners. HP Tuners VATS off setting simply has the ECU ignore the security warning and never shuts the fuel supply off at 2mph or so. If you don't want the error message too, you have to defeat the error via the resistor mod or LMC5 install - OR replace the actual defective component(s).
Old Mar 28, 2025 | 02:59 PM
  #45
CJL64's Avatar
CJL64
mmartinez said ....Never heard about a VATS bypass module? Most people simply soulder some resistors at the BCM connector after cutting the two wires from the Ignition switch. Simply measure your car keys resistor pellet and purchase two resistors to match the resistance value of the key pellet.
Genius. I read these posts to learn and hopefully remember if I have a problem.
Old Mar 28, 2025 | 03:03 PM
  #46
lucky131969's Avatar
lucky131969
Why two resistors?
Old Mar 28, 2025 | 03:11 PM
  #47
CJL64's Avatar
CJL64
Originally Posted by lucky131969
Why two resistors?
Not sure about two resistors .. that was a quote. I just like the idea of putting a resistor on the ign switch and not having to worry about matching key blanks. Maybe standard resistor values require two to get it in the finite range needed.
Old Mar 28, 2025 | 06:01 PM
  #48
mmartinez's Avatar
mmartinez
I said two resistors because resistors are sold by certain resistance values and I don't know if you can buy just one resistor that is the correct value and you have to series two resistors to arrive at the correct value. Oh and I saw a pic of the mod on the BCM connector and it was two resistors.
Old Mar 28, 2025 | 08:34 PM
  #49
donjetman's Avatar
donjetman
It took 2 of them to get the correct total resistance when I did it.
