Katech cnc porting bundle for 243s
Old May 21, 2025 | 04:51 PM
vette4fl's Avatar
vette4fl
Over my budget, although it looks a good package.
I offered $1,000 so not very likely, but what the heck…
Old May 22, 2025 | 04:35 PM
Lowend's Avatar
Lowend
Those SDPC heads look like a bargain. Anyone here tried them?
Old May 28, 2025 | 08:35 AM
Pipedream's Avatar
Pipedream
Just revisiting this... (heads are at Katech now...)
Golan and SDPC don't publish (I cannot find it...) intake runner sizes. As mentioned above, I am not interested in some hog'd out 225+ intake runner option. These are going on a 346 (for street use...), and of the 6 head\cam cars I have wrenched on, 3 had huge intake runners and were mushy, soft low rpm performance (cam of course matters...)... until they were twisted to plus 4000rpm. I simply don't live at 4000+ rpms. I drive the car daily, in traffic, in parking lots. The Katechs got their flow numbers with only a 215cc intake runner, which is only 5 CC larger than the factory 243s. In short every modification is a compromise, I am shooting for some balance.
Hopefully 2 weeks will tell...
Old May 28, 2025 | 12:04 PM
vette4fl's Avatar
vette4fl
I use my car the same way. Local city driving and occasional short rips to 4K—5k.
What are your cam specs?
Old May 28, 2025 | 12:05 PM
vette4fl's Avatar
vette4fl
Pulled the trigger on these…
Stripped my 243s of hardware and sent them in…. will see what the final product is.
Did you get the full package or ala cart?
Old May 28, 2025 | 12:19 PM
FourG63 97GST's Avatar
FourG63 97GST
curious on the update on these when you get them back
Old May 28, 2025 | 12:35 PM
gnx7's Avatar
gnx7
I've had Katech do a couple sets of LS9 heads and they do great work. My bill was always around $1500-1800.... obviously hoping for less. They replaced valve guides, exhaust valves, CnC, deck, clean, disassemble, reassemble etc. I supplied the dual BTR springs.
dankhts's Avatar
dankhts
Originally Posted by Lowend
That's not exactly accurate as the Golen heads are outright with no core. I'm sure you could save some $ shipping yours to Golen for porting instead.
Texas Speed sells their outright heads for $1999
Golen As Cast are $1900 and CNC Ported ar $2400
Point of reference: Comparable Lingenfelter Heads are $2209 including $500 core charge. People always forget about them now...
TSP definitely has its detractors. They've never wronged me, but I know people they have
I ran Lingenfelter 243s for years on my C5, 100's of passes at the strip, had them freshened up once in 15 years... great heads ... just sayin...
I had all the flow sheets and dynos, but can't seem to find them ... sold that C5 in '19 and bought a Grand Sport...
Old May 29, 2025 | 09:23 AM
Pipedream's Avatar
Pipedream
I opted for the full package...
My cam is 224/228 .600/.600 114+4
Old May 29, 2025 | 10:01 AM
JHrinsin's Avatar
JHrinsin
I would be interested in your results as well, base on my similar camshaft specs. Do you have dyno results of you current combo before sending the heads off to Katech?
Old May 29, 2025 | 02:43 PM
redzg's Avatar
redzg
That should result in a very fun combination.
Old May 29, 2025 | 07:37 PM
Pipedream's Avatar
Pipedream
Nope... but completely factory 2002 - 2004 ZO6s dyno between 355 and 365 (rwhp) all day long.
There are some low ***** and some HP freaks... but those are the middle numbers.
... on a side not I am ditching the LGs and getting a set of American Racing headers. I am also getting the rear diff rebuilt with 3:90s.
Old May 29, 2025 | 08:05 PM
  #33
vette4fl's Avatar
vette4fl
365 / .85 =429.412.
344 / .85 =404.706
I believe the accepted power train loss on a manual C5 is15%. In that case 405 hp would make 344 at the rear wheel.
Who knows for sure…but I have found this to be the case with my two C5’s…
Old May 30, 2025 | 06:37 AM
  #34
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Let us know. I'm debating between Katech and TSP.
Old May 30, 2025 | 09:11 AM
  #35
Supercharged111's Avatar
Supercharged111
365 / .85 =429.412.
344 / .85 =404.706
The multitude of people who've dyno'd know for sure, unless dynojets are unrealistically optimistic. Those (DJ) tend to be the numbers that I see quoted the most and they tend to land in the 355-365 range. Stock manifolds, free flowing catless exhaust, and a dyno tune should have an LS6 at 380whp all day. Just ask the Spec Corvette guys.
Subbed for OP's feedback on these heads. I've long kicked around the idea of them. I have a similarly sized cam waiting to go into mine as well.
Old May 30, 2025 | 11:08 AM
  #36
vette4fl's Avatar
vette4fl
Wow…. Looks like only a 7% power train loss ! That’s amazing.
380 / .93=408.602
Old May 30, 2025 | 12:11 PM
  #37
JHrinsin's Avatar
JHrinsin
I know the below link is a very old post on the subject, but it is from TonyM;
https://ls1tech.com/forums/generatio...ml#post5181827
Below is the image from Katech's website which seems to agree with what TonyM was saying nearly 20 years ago. I would think that Katech's 215cc intake port would help any combo breather better at top end vs stock 243/799 castings - while also helping to minimize any torque lost below 4000 RPM due to lower intake charge velocities, which dyno testing has confirmed with the larger CNC 225-228cc intake ports on say a 5.7 to 6.0L LS engine.
Basically it comes down to where you want / need the power to be in the RPM range. Personally (due to the -2cc valve relief in my forged pistons) I would also want Katech to mill the heads slightly to get back closer to the 64.5cc chamber size to maintain the stock LS6 CR target and / or at least run a set of Cometic 0.040" compressed MLS head gaskets for the same reason.
For most of our street driven miles, I would also think mid range punch from improved torque is more important than top end dyno bragging rights, but as always YMMV.
To Katech cnc porting bundle for 243s
Old May 30, 2025 | 01:48 PM
  #38
vette4fl's Avatar
vette4fl
That’s precisely why I had my cam configured with .587 lift (I told CamMotion .590 max and they decided on .587 …). I’m no expert for certain, lol, but my “research” indicated stock 243 heads potential is around .590 lift. So with CNC and headers, I hope to break out of that flat spot (shown in the Katech graph) in the .450 to .600 range. I strictly street drive so a strong midrange rip to about 5,200-ish is the most it’s going to see before speed, even in second gear, becomes the performance limiter.
Like others have said, the dyno is a tuning tool, so not too hung up on numbers, as long as the butt-o-meter approves.
Looking forward to the results for the OP.
Old Jun 8, 2025 | 07:22 PM
  #39
Pipedream's Avatar
Pipedream
I was told they would be done this week... then shipping time.
... that being said... the TSP's are large intake runners... 225+cc, from what they (TSP) told me. Great at WOT, 4000rpm+ again, simply not where I drive the car.
Old Jun 8, 2025 | 07:44 PM
  #40
vette4fl's Avatar
vette4fl
See the light!
